Results 1 to 9 of 9
Thread: First time AGP owner - need help getting up and running
    May 2012
    Longwood, FL
    30
    Hello to all, I have been reading this board since we decided to jump into the world of pool ownership . I have read Pool School and toyed with the pool calculator. I have also read tons of various posts (very informative board) on all areas from leveling, decks, chemistry, CYA, etc. This is our first ever AGP and we are trying to get it going right so we can start enjoying the water. Here is a rundown of what we have done so far:
    1. Set up pool on Saturday morning (5/19) and began filling with water around 10:30 am, the pool was filled by 4:30 a.m. the next day.
    2. Let pool sit pool until Monday morning when the electrician installed the dedicated 20A GFCI outlet near the pool location.
    3. Backwashed filter and then turned it on (5/21 9:30 a.m.)
    4. Added ~ 180lbs of salt, stirred it up and left pump running for 24 hrs.
    5. This morning (8:00 a.m.) I did a salt test (aqua chem) and it read ~ 2660 ppm. I wanted to get into the range suggested by TFP, so I added another 20 lbs of salt and turned on the SWG for 3hrs per the Intex manual
    6. This afternoon (2:30 p.m) I added 1.7 lbs of cyanuric acid (amount recommended in Intex manual) to a old sock and placed it in the skimmer.
    7. Ran another salt test around 6:30 this evening and got the same reading as earlier ~2660 ppm.
    8. Used aqua chem 6-way test strip and got the following results:
    Total Hardness - 250 (CH = 2/3 x TH = 167)
    Total Chloride - 0
    FC - 0
    Bromine - 0
    pH - 8.4
    TA - 120
    CYA - 0
    Questions
    I read that it takes CYA a while to establish, but I am confused with the FC number. Do I need to run the SWG for a longer time, should I run it through another cycle tonight?
    Is there anything I should add in the meanwhile to get the FC up? What should I do about the pH being high (muratic acid)?
    Any help or suggestions would be appreciated.
    Wil
    20,000 gal, IG plaster, Hayward DE 3620 (72gpm), Flotec 1.5HP
    TF-100 kit
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,051
    Re: First time AGP owner - need help getting up and running
    pH needs to come down. Now.
    Just use bleach to get some FC registering until the CYA is all dssolved. What FC the SWG produces is probably being broken down by UV sunlight faster than it can be made.
    May 2012
    Longwood, FL
    30
    Thanks for responding, how much bleach should I add? I entered my info in the pool calculator (6981 GAL and FC= 0) and it tells me add 87 ounces of 6% bleach...is this correct?
    TF-100 kit
    Richard320's Avatar
    Jan 2010
    19,051
    That's what I get.
    May 2012
    Longwood, FL
    30
    Thanks, I added 87 ounces of bleach this morning and will retest later this evening.
    TF-100 kit
    May 2011
    Hardy, Virginia
    61
    Are you testing with just strips, or do you have a good test kit? By good I mean Taylor K2006 or the TFT...
    15' wide x30' long x 4.5' deep vinyl above ground, 13,500 gallons, hayward dream line sand filter, hayward power-flo lx pump 1.0 hp, lil shark cleaner
    May 2012
    Longwood, FL
    30
    For now I am using the strips from a "not so good" kind. I have not ordered the good one yet, looking at the TF100.
    TF-100 kit
    May 2011
    Hardy, Virginia
    61
    That's perfect. I think you'll find it's a lot easier to manage your chemistry when you have that kit.
    May 2012
    Longwood, FL
    30
    I did the following today and got the results below (shown in comparison to yesterdays results).
    Added 87 ounces of bleach this morning.
    Ran the SWG for 3 hours.
    Squeezed sock with stabilzer near return until it was all dissolved.
    Total Hardness - 250 (CH = 2/3 x TH = 167) ---no change
    Total Chloride - 0 ---no change
    FC - 0 --- no change
    Bromine - 0 --- increased to 2
    pH - 8.4 --- decreased to 7.8
    TA - 120 --- increased to 180
    CYA - 0 --- increased to 50
    Salt - 2660 --- increased to 2860
    I am still not sure why I am not registering any chlorine? any thoughts? do I need to add another round of bleach?
    TF-100 kit
