Results 1 to 11 of 11
Thread: Pergola electrical question
    We are planning our pool build and are planning on a 8x10 pergola and since we will be pouring concrete already I am going to have them set the 4 6x6s in concrete. My question is how do I hide the electric I am going to be running to it? I plan on running one wire and having a few outlets. One hidden in the cabinets for a fridge, one in the counter and one up higher for a tv. What would be the best way to hide these out of sight? I have ran many wires through my attic, under my house, through walls for alarms, electric projector screen and many other items all hidden out of sight but I can not think of a way to hide these wires. Can electrical wire be poured in concrete if it has extra protection?
    18x36 Grecian Vinyl; 8' Roman steps w/t 2 spa jets; cozy cove w/t 6 spa jets; 2 MD, 1 Skimmer, 3 returns; Hayward Ecostar, 30" Ranger sand filter; Hayward color logic 4.0 LED light; Hayward aqua logic; 2" PVC pipe 4 Jandy Valves
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    Re: Pergola electrical question
    Conduit in the concrete.
    Mar 2008
    Wake Forest, NC
    128
    I wouldn't set the 6x6 in the concrete to begin with. I would lay conduit in the concrete to one of the 6x6 locations and then route the wire up through the 6x6. Then drill out he 6x6 for wire and bolt it to the deck. Fish the wire through the conduit. you just have to leave room for the bolts to not interfere with the wire.
    Alternatively you run the conduit to the location right next to the post location and run it up the side of the post. You just need to plan ahead and measure measure measure....
    IG Vinyl liner, 21,500G sport bottom, TR-60 sand filter, 3/4 HP Whisper Flow, BBB with 12.5% Liquid Chlorine
    SW Georgia
    300
    You could substitute a hollow column for one of the 6 x 6's. You could make this out of 2ea 2 x6's and 2ea 2x 2-1/2 pieces of lumber, this would replicate the size of the solid 6 x 6 columns. The down side is that you may be able to see the joints but if you bought 2 x 8's and cut them down to 2 x 6 you could minimize this, as most store bought lumber does not have crisp corners. Your conduit could stub up in to the cavity. If you put some extra conduit you would have some expandability for other electronics down the line.
    35K IG Vinyl 20 x 40 self built pool, Hayward Pro Series High-Rate Sand Filter 31" 98gal/min, Hayward TriStar 1.85hp, Hayward 400btu heater, BBB method w/Hypo, Jazz light w/matching fiber optic rope lighting around coping w/syncronized color wheels. Concrete Paver deck.
    Melt In The Sun's Avatar
    Oct 2009
    3,899
    Wood set in concrete is never a good idea! If you haven't already done it, it's better to get the brackets that the 6x6s bolt into; the correct name for this part escapes me at the moment...
    Thanks all great ideas. I know which brackets you are referring to. How long does the Crete need to cure ? I know normally it is like what 54 days to fully cure or something but could I drill into it say within a week or 2?
    May 2012
    CDA, ID
    18
    If you dont mind me chiming in I agree with the idea of not mounting your wood in concrete. Use the brackets or build it stout enough that it wont move on accident. It can be hard to hide where the electric comes into the pergola at. I recently bought the wood for a pergola but due to a pool leak and a ripped up front yard the wife says that I am unable to start that until the previous two are fixed. I have electric ran to where my pergola will be via conduit coming up through the cement. I plan to Dado all four sides of treated 6x6 and then wrap them in rough cut cedar. By dadoing the center of every side of every post I will be building a channel that I can run wires through. I know it probably sounds like a lot of work but it was the best I have came up with so far.
    28k Gallon IG Pool, Vinyl Lined, 1hp (1.65 max BHP) Sta-Rite Max-E-Glas PE5E-182L single speed pump, RayPak heat pump, Sand Filter
    Mar 2008
    Wake Forest, NC
    128
    Hyder's is now the way I would do it! Interesting name vs thread/post content there.
    run pvc pipe and they make what is called a chair. it is a pvc bracket that is flat on the bottom and rounded at the top. the may cost a $1 or 2 each call a local electrical supply house ask for what ever size pvc you need and a couple chairs. i think you need 3 per 10ft pc. pull the wire before you pour the concrete alot of people juse pull the pullrope thru pipe and bad things happen. also pay the extra money for gfci receptacle since your going outside
    32000 gal , gunite pool, de filter weber gensis and tiki bar
    Use Simpson Strongtie concrete anchors for the posts. You set them in the wet concrete and the attach the posts to them. They have a standoff plate so the posts are not in contact with the ground and won't absorb water. There are lots of choices depending on thickness of your concrete and the loads (uplift and down). For example, PBS66, CBSQ66, ABU66, etc.
    I've done a variation on hayder710's idea.
    I've routed a dado in the side of the post with a 3/4" router bit and set the romex in the dado. On the table saw I'll rip a strip of wood, 3/4" wide by about a 1/2" deep. Use titebond and glue the strip into the dado. Tap it in, belt sand if needed. The glue lines pretty much disappear.
    20' x 40' plaster pool with 6'D 4-jet spa. Estimate 23K Gallons
    Raypak ASME 400k propane heater, Pentair Intelliflo pump, Pentair Quad DE 100 filter
    Liquid Cl via Stenner 45MPHP10 pump and Intermatic HB880R timer
    Loop-loc cover, Letro Legend II sidewall cleaner, soon to be replaced
    Live in CT, use pool from mid-APR to mid-NOV
