Thread: converting bacquacil to chlorine
    May 2012
    Boston, MA
    2
    I decided to switch from bacquacil to chlorine when opening my pool this spring. I assumed after 8 months the bacquacil was gone from pool....WRONG!! Now I'm pouring shock in by the gallon and the chlorine is still not registering on test strips, the pool is green and the pump needs to be backwashed every two hours as the pressure rises very quickly. This wouldnt be a problem if I didnt have to go to work all day. Is this nightmare normal? how long before pool is clear. Any suggestions?
    Butterfly's Avatar
    South Carolina
    10,045
    Re: converting bacquacil to chlorine
    Welcome to the forum
    We have complete instructions on how to convert from baqua in Pool School. Big white button, top right of each page.
    What test kit are you using?
    You're done SLAMing when:
    22,550
    Welcome to TFP.
    Sep 2009
    Greentown, IN
    914
    Yes, it's normal, and no, it's not gone.
    A conversion takes some work. If you search you can see the efforts of others that have done the same as you. Hang in there and keep that chlorine handy, and be ready to backwash regularly. If you don't have a good test kit... get one pronto. There are a couple of good ones mentioned in the pool school section of this site.
    Indiana, ABG 24'x52" Galveston by Blue Cascade (Craigslist buy w/part of deck included), 13,500 gallons, Intex SWG, solar panels mix 2, TF-100 test kit.
    Test kits compared
    Purchase test kits
