Thread: Brown water - Sequestrant question.
    We have well water. We're having a problem with our water turning brown every time we shock. We have yet to get our pool clear since it's been open 2.5 weeks ago. It's a cycle. We need to shock to get the water clear, but everytime we shock, our green/getting clear water turns brown. So we need to add metal out, or the one one I had on hand was Sequa-Sol by GLB.
    So how do I end this cycle?
    How much sequestrant should I be adding. Maybe I'm not adding enough to get all the metal out. How long should I wait until I shock after adding the Metal Out etc.?
    I don't have any test results right now. I haven't taken any because the water's not clear and I know things are off. Would it help to know the other readings when trying to figure out this problem? I have a Taylor kit.
    Re: Brown water - Sequestrant question.
    It is best to add sequestrant before shocking. I would start with the startup does as recommended on the container. If the pool starts to turn brown, add more.
    solarboy's Avatar
    Aug 2010
    Europe
    337
    I overfill, shock, floc, vac to waste, backwash. I haven't had staining issues doing this but I don't speak for everyone in all situations. I believe this method actually gets rid of iron as opposed to "sequestering" it.
    Self built 5500 gallon bare concrete (temporarily) pool with limestone coping, Pentair Swimmey 1/2 HP pump, Triton sand filter with DE, Simpool peristaltic muriatic acid pump with pH sensor and Monarch SWG. Home made solar heater with Pentair Compool control panel and 3 way valve. 1 skimmer, 1 main drain, 2 returns, 2" plumbing, Hayward auto fill valve.
