Results 1 to 8 of 8
Thread: liquid bleach instead of pucks?
    Feb 2012
    Frisco, Texas
    17
    Am I reading pool school correctly. I use bleach INSTEAD of pucks? Or is it to supplement/shock as necessary in addition to the use of pucks?
    22,000 Gallon, IG, 608 sq feet, 114 feet perimeter, Tahoe Blue Pebblesheen Plaster, Jandy 60 Sqft DE filter, Intelliflo SVRS pump, Jandy PDA4, 2 Jandy LED Pool Lights, Letro Autofill, Polaris 280 with booster pump, Rainbow 320 Chlorinator, Nature 2 in-line, 3 ft sheer decent, bubbler on tanning shelf, 472 sq feet seeded aggregate deck, Oklahoma Flag stone coping
    Re: liquid bleach instead of pucks?
    Yes, we recommend using liquid bleach (or a SWG) instead of pucks.
    Feb 2012
    Frisco, Texas
    17
    Thank you.. I do not have a SWG. Is everyone using a dispenser of some sort, or just pouring it in manually?
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    Some pour manually. I have a Liquidator, which is an automated liquid feeder. There are other options as well.
    The advantage of bleach over the pucks is that bleach doesn't add CYA to the pool. Pucks are fine if you need everything they add, but our philosophy is to understand what you are adding and how it will affect your water before you add it.
    gboulton's Avatar
    Apr 2012
    Nashville, TN
    380
    I pour mine in manually.
    I'm weird though...I don't see it as a task so much as a chance to get outside early in the morning, "commune" with my pool a little, and just eyeball everything for a few minutes, make sure everyone's all happy and in good running order for the day.
    -Gordon
    Pool School helps me maintain my 13,500G 24' x 48" ASP with Sand Filtration using a TF100 Test Kit and Pool Calculator.
    Remember, the Shock Process should be followed until : 1. CC is less than 0.5 ppm, 2. An OCLT shows a loss of 1.0 ppm or less and, 3. The water is crystal clear.
    --I didn't buy my pool to swim in it. I bought my pool to watch my wife swim in it. :wink:
    dmanb2b's Avatar
    Apr 2009
    NY
    3,734
    "Dr...I suspect the patient has a severe case of sparklypoolitis"
    30,432
    I completely agree, dman, gboulton is afflicted and there is no cure that I am aware of.
    gboulton's Avatar
    Apr 2012
    Nashville, TN
    380
    And here I just thought I was a morning person.
    -Gordon
