Thread: TA is 190
    homeschoolmoxy's Avatar
    Jul 2011
    Northern NY
    29
    TA is 190
    We opened our pool last week. How exciting it was to see the crystal clear water - thanks to troublefreepool.com. Didn't know what to expect since this was our first winter.
    We finally had the water topped off and the filter is running now. I did my first tests
    CYA 20
    TA 190
    ph 7.5
    FC 4.5
    CC 0
    I think I'll add a bit more CYA to bring it up to 30, but should I worry about the TA? Or can I leave it alone as long as the ph doesn't rise?
    Thanks
    27 foot AG vinyl pool (17100 gallon) - Sand Dollar Filter 1.5 hp 2 speed pump
    TFTestkit
    38,305
    Re: TA is 190
    If you are not getting an unacceptable pH rise, then leaving the TA should not be a problem. If you decided to slowly lower it, read Lowering Total Alkalinity for the process.
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    Re: TA is 190
    I've dealt with extremely high TA for a long while. My fill water is typically around 480ppm. The water I trucked in to fill the pool originally was 240ppm, so I know the drill. It took me two years to get mine below 200ppm, with attention to pH and rainwater.
    I just tried to stay on top of the pH and to go for the low end of the range. Try to keep it at 7.1 or 7.2, and you'll slowly get rid of your alkalinity. If you have the time on the weekends, adjust your pH a few times a day and use a fountain or the return angled up to accelerate the process.
    No real need to be in a hurry, but if you are going to fight pH anyway, fighting it at the low end will eventually reduce your TA, while fighting it at the high end is just annoying.
