Results 1 to 17 of 17
Thread: New Equipment Install - Test now?
    Jul 2011
    North East
    135
    Hey guys/gals,
    Took the cover off in preparation for a new pump and filter install coming up at the end of this week. The water was clearish with a green tint and is now full green from an algae outbreak. Should I do an initial test now or wait till the equipment is install and the water is circulating to test?
    25,000 gallon Concrete/Plaster Pool
    Pentair WFDS-26 - Installed Spring 2012
    Pentair Quad DE 100 - Installed Spring 2012
    Pentair Kreepy Krauly 820 - In Service 05/26/2013
    K-2006 Test kit, Intermatic P1353me Digital Timer, Stenner 85MHP5
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,591
    Re: New Equipment Install - Test now?
    You might as well wait until you can circulate the water, chemicals, and filter out dead algae. It would be an absolute dogfight to try without it.
    38,274
    You need the water circulating before you test so the water is pretty much uniformly mixed.
    Jul 2011
    North East
    135
    Thanks for the replies. I'll post back when its up and running with the results
    Jul 2011
    North East
    135
    The install got pushed back til mid next week due to additional plumbing parts being needed so our pool is a nice Ninja Turtle Green right now. With the heat over the next couple days I'm sure it'll get even worse
    Should I dump some chlorine in the pool or is that just a waste since their is no circulation?
    On the bright side the plumbing setup is going to be much nicer and cleaner than the previous owners had it.
    30,416
    Wait until you can circulate water. Stock up on bleach and be ready to test often.
    Jul 2011
    North East
    135
    have 15 gallons of 12.5% ready to go anxious to get this bad boy going! I do need to buy some more reagent for the chlorine test but i have enough to get me started anyway.
    I'm curious to see where the cya reading will be...last year at the end we were barely at 30ppm and we lost chlorine at a pretty fast rate so I'm thinking we need to be in the 50ish range this year.
    Also, whats the shelf life of muriatic acid? I have a gallon left over from last year thats been in the shed since then.
    Jul 2011
    North East
    135
    Where would be a suitable place to store the 5 gallon carboys of 12.5% chlorine?
    I was thinking either the laundry room or basement but want to ensure its ok to do so first due to any potential off gassing hazards (if any) etc.
    Jul 2011
    North East
    135
    bueler?
    30,416
    Any place you can keep it out of the sun. If the carbouys are in good shape, they are airtight.
    Jul 2011
    North East
    135
    Ok great! Is the muriatic acid I have from last year still viable or should I get a fresh batch?
    Aug 2010
    Dallas, TX
    4,052
    MA has a long shelf life. Just don't store open containers in your garage or anywhere enclosed. Boy I learned that lesson the hard way.
    Jul 2011
    North East
    135
    Quote Originally Posted by RobbieH
    what happened? I've had mine stored in my shed with a window cracked.
    Aug 2010
    Dallas, TX
    4,052
    Everything in my garage that was unprotected metal rusted. What a mess. At first I thought it was because of the Liquidator, but we figured out it was the MA later. I have a show car too, luckily all I had to replace was the header bolts (they needed to be replaced anyway) and a few odds and ends. Some other parts we had laying around to assemble a 350 for a Jeep were almost destroyed. I did have to buy a new thermostat, it was brand new and turned to rust.
    Jul 2011
    North East
    135
    eeek. Where do you store it now, particularly during the off season?
    Aug 2010
    Dallas, TX
    4,052
    I have a fenced off area where my A/C compressor and all my firewood is stored. I have some old steps from a spa I gave away, the guy didn't want the steps, so I use them as shelves and store it there. I'm afraid to even store it in my well-ventilated sheds after my experience.
    Chlorine and muriatic acid are both corrosive if the container isn't sealed. In properly sealed containers they are fine. The risk is that the seal goes bad.
