Page 1 of 2 12 LastLast
Results 1 to 20 of 22
Thread: holes in main drain clogged
    Feb 2012
    alabama
    54
    I have recently started the BBB method about a month or so ago. Had a swamp. Now I have a sparkling beautiful pool thanks to everyone on here. My problem is I have some trash, leaves, etc. clogging up my main drain. Turned it off, sent my nephew down to see what he could do. Hurt his ears. So Saturday, I sent my 19 year old daughter down. She has helped with this in the past. She also could not stay down very long because it hurt her ears. She couldnt pick anything out, so I sent her down with a butter knife to poke through. She said she only could get some of it. But after she did that, I am having lots of trouble with air being pulled in when I turned the main drain back on. So not only do I still have trash clogged up in the holes, I think she may have lodged something in the pipe. (not her fault, I sent her down there). But, does anybody have any suggestions on how to unclog the main drain? And I should add, diving to the bottom also hurts my ears. I will be willing to suffer it if I can figure out something that will work. Please help!!
    18x52 round intex ultra frame
    vinyl
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    Re: holes in main drain clogged
    Don't get close to it while the pump is on to avoid any kind of entrapment.
    Dive down a few times and your ears should adjust better to the pressure.
    Turn the valve on to whatever amount of flow through the drain you can get without the pump losing prime and use your brush to try to free it up from above.
    38,546
    Seems unlikely that you could push something through the drain holes that would clog the pipe. You do not need to be pulling water from the bottom drain for circulation ... many pools do not even have them. Just keep brushing away or try vacuuming the junk out.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,075
    Try blowing the stuff out backwards using a drain king. If you have the setup where the main drain goes up the skimmer, it ought to be easy. If not, then isolate the main drain with the valves, pull the pump strainer basket, and try feeding the drain king through the pump inlet.
    Feb 2012
    alabama
    54
    I always thought I should run both main drain and skimmer for the best circulation. I have brushed a lot of it away, but theres some that's just stuck. Do I really not need to pull from the main drain for just normal filtering?
    vinyl
    SW Indiana
    9,199
    Quote Originally Posted by Machelle
    It's not mandatory, but it is helpful to circulate water and it can save your pump if a storm were to blow leaves or a plastic bag in the pool that blocks the skimmer.
    Feb 2012
    alabama
    54
    Quote Originally Posted by JohnT
    I have turned it off and brushed and brushed and brushed. But I will try the dive technique you suggested to see if I can adjust my ears.
    vinyl
    Feb 2012
    alabama
    54
    Quote Originally Posted by Richard320
    Can you give me a little more detailed information please? I don't understand how this works.
    vinyl
    Feb 2011
    Petaluma, Ca
    665
    You need to plug your nose and try to blow out through it when your at the bottom, better on the way down, this will equalize the pressure. You dont have to do much and you'll feel them "pop".
    DONE, 20 x 40, inground gunite, 30" raised bond beam with 3 12" sheer descents, 8' diving board, pentair 420 cartridge filter, vs-3050 pump, intellechlor ic-40, auto cvr, Tahoe blue pebble tech, 6ea 4' x 12.5' & 2ea 1' x 12.5' helicol solar panels, legend robotic cleaner.
    Richard320's Avatar
    Jan 2010
    19,075
    It hooks to a garden hose. When you turn on the water, it inflates and locks itself in the pipe. And then it builds pressure and blows whatever obstruction is in the pipe out.
    Any hardware store with a plumbing section will have them.
    Feb 2012
    alabama
    54
    Tried the drain king. not enough pressure i guess. Could see water moving around, but nothing came out. Is it possible to remove the drain cover, clean it, then replace it? I do not want to damage my liner.
    vinyl
    38,546
    Most drain covers (I do not know about liners though) are just screwed into a housing. I would think the housing hold the liner and the cover would be removable. Of course you have to be able to get down there and stay there while unscrewing ... if you have a dumbell or something like that to hold on to while on the bottom it helps to keep you there.
    Feb 2012
    alabama
    54
    I am still having problems with air in my line. It is really bad when I have the main drain on. The air is only coming out of the shallow end return line. Everything seems to be working fine except for the air in the line. There are bubbles in my pump basket. A lot of them, but pressure seems good. I seriously cannot afford to have someone come out and check my lines. Struggling to just pay for upkeep. Does anyone have any suggestions?
    vinyl
    22,553
    Try running water over the pump basket and plumbing while the pump is running and see if the bubbles get less or go away. If they do you've narrowed your leak down to that point. Post back what you find and we'll help more.
    Feb 2012
    alabama
    54
    Thank you Bama Rambler. I will try that this afternoon after work.
    vinyl
    Feb 2012
    alabama
    54
    Tried the water test. When I ran water over the pump basket, the air got a little worse?? It pretty much stayed the same when I ran it over the plumbing. And the air is still only coming from the shallow return. Its all really confusing to me. HELP
    vinyl
    Have you tried removing the pump basket lid, cleaning all surfaces including the face that it mates to on the pump and lubing the gasket with pool lube?
    I had an air leak that I finally found on the suction side connection between the pump and PVC. Cleaning and a quick lube fixed it for me.
    19000 gal gunite,
    600 gal hottub,
    Intelliflo variable speed pump,
    Pentair 420 filter,
    Pentair 400k heater,
    Hayward Navigator Pro,
    TF-100
    Speed Stir ->->-> Great tool for easy testing
    Feb 2012
    alabama
    54
    Quote Originally Posted by vegaspool
    I have not tried that. What should I clean it with? And are you talking about the lubing the gasket on the pump basket lid?
    vinyl
    Clean the lid and contact surface with hot soapy water then lube the gasket with a product such as POOL LUBE
    Yes the pump basket lid gasket......... its the easiest to start with, then the gasket for the in flow to the pump.
    19000 gal gunite,
    600 gal hottub,
    Pentair 420 filter,
    TF-100
  20. Back To Top    #20
    Feb 2012
    alabama
    54
    Thanks. I will try it and post results tomorrow
    vinyl
