Thread: HELP with CYA
    HELP with CYA
    I am trying to recover from an algae take over. My CYA is 0. Took a water sample to the pool store and they did not measure CYA. They are telling me I just
    need to keep feeding my pool chlorine until it starts to hold. Will my CYA eventually raise on its own by just adding the chlorine to the pool? I also have a Nature 2 filter that I have not started as I do not know if it will help or hinder. Water is pale blue and cloudy....barely able to see bottom of pool.
    Thanks for advice!!
    Feb 2012
    Phoenix, AZ
    728
    Re: HELP with CYA
    First of all, pool store test results are notoriously inaccurate. It would be wise to get your own (good) test kit to take full control of your water.
    If you are adding chlorine using tabs, these also contain CYA. However, you will want to get your CYA up faster than tabs can handle..so you might consider adding stabilizer (liquid or granular is fine) to get to your desired level.
    Based on the description of your pool, you need to go through the shocking process to clear up your water. Read instructions in Pool School several times before even starting this process. If it is not done correctly, you will waste time, chemicals, and money.
    Hold off on the Nature 2
    Welcome to TFP!
    May 2012
    Small midwest town In illinois
    55
    Re: HELP with CYA
    I just started on the same journey as you. I purchased a good testing kit, as recommended by the smart people here. I started to shock my pool with bleach only, and had no CYA when I started as well. My pool was a pale green color, and and unable to see the bottom, as of last friday. I have kept my chlorine levels (bleach) steady for the "SHOCK" phase. Added the CYA (stabilizer, in a nylon sock) ran filter 24/7 and today I can see the bottom. I am almost there. The pool calculator is a GREAT! Ask lots of questions, as everyone here is very friendly. I have to say read up on the BBB method. I have found it much cheaper and more reliable. With the "Pool Store Chemicals" you never know exactly what you are adding, as the BBB method is very precise.
    Also, I threw out my nature 2, very expensive refills, and is not needed, for a crystal clear pool. I am just a n00b as well. I am just learning. This site has helped me very much!
    14,600g / 24ft. Round Above Ground with Solar Cover and solar heater panel.
    Vinyl Liner
    Hayward Cartridge Filter (CCX 1500RE)
    2 HP Hayward Powerflo LX Pump
    Pool and solar heater get full sun, when its shinning daily!!
    Using test kit: Taylor K-2006
    Successful BBB user.
    Re: HELP with CYA
    Thanks for the replies. I wish I had found this site a week earlier....(and about $200.00 dollars sooner!!) I have never had water tested at a pool supply center until this year. I am
    fairly confident that I will not again. I have maintained a pool for 5 years previous to this year with no problems using most of the items in the BBB method. I wish I hadn't doubted myself, but
    a move from city water to rural water made me do just that. In the short time I have navigated this site I have been very impressed with both the wealth of knowledge it contains, and the willingness of everyone to share their experiences and advice. Thanks again and I will keep you posted on the pools progress. (Cross your fingers!!)
