Results 1 to 9 of 9
Thread: Help my daughter has a rash!
    Apr 2012
    Mount Carmel, PA
    8
    This is my first year doing the BBB method. My 8 year old daughter develops a rash every time she gets in the pool. I'm thinking it must be the Borax. Has anyone else experienced this? Is there a way to get it out? Ph 7.6, Cl 3ppm, CYA 35, Alkalinity 75
    14' x 28' Grecian Vinyl IGP 13,300gal, Hayward SP2607X10 Super Pump, Hayward C1200 Star-Clear Plus cartidge filter, TF-100, Taylor k-2006 test kits
    22,550
    Re: Help my daughter has a rash!
    How did you get those test results? Kit, pool store, etc.
    How long has the pool been open?
    Your chlorine is a little low and if that's TC and not FC you may have a problem.
    I doubt it's the Borax.
    Apr 2012
    Mount Carmel, PA
    8
    Pool has been open 2 weeks. Results are from a strip. I don't know if it is TC or FC, I believe most strips show TC.
    38,299
    You need a better way to test your pool. Which strips? (although they are all pretty much useless). Some will measure FC and TC. Although for all you know you have 0 Free Chlorine and 3ppm of Combined Chlorine (which is the bad kind ).
    Getting one of the recommended test kits (see my sig. for a link) will be one of the best investments you can make for your pool ... especially if it prevents the rashes which take away the enjoyment.
    22,550
    Yep, most strips show TC so you could actually have zero FC and 3 ppm CC but more likely it's a combination of the two.
    You need good test results so we can help you figure out what's going on. For a pool your size I recommend you get a good test kit. If you already have a pH test you can get the TF-50 from tftestkits. Even then I recommend the TF-100. The K-2006 can be had from the same place if you'd rather.
    JB and I are saying the ssame thing but he beat me to it! I'm posting anyway!
    Apr 2012
    Mount Carmel, PA
    8
    Two posts saying the same thing- I'll order myself a kit today! Thanks
    Apr 2012
    Mount Carmel, PA
    8
    Received my TF-100 on Saturday. Results were very similar to the strips. Good news is the rash cleared up before I even received the TF-100 and it hasn't returned. (it may not have been the pool).
    I am very pleased with the test kit, glad I had a reason to purchase it. I do have one question- When I do the CYA drop test what sort of light should I be in? Outside in full sun, in the shade or indoors?
    frogabog's Avatar
    Jul 2010
    Portland, Oregon
    1,578
    Best is full sun, with your back to the sun. Hold at about tummy level and pour till the dot is completely obscured. You can do the CYA test multiple times with the same solution (it'll stay cloudy and fairly accurate for a long while, unlike the other tests) and then use your best number from all the pours.
    Where kids swim in 54 degree water, turn blue, and giggle happily cuz they got a POOL!
    Year 3 BBB -15' x 48" Intex Metal Frame - Was using (2) 1000gph Intex cartridge filters (see Full time pumping Intex). 2012, converted to 1600gph and sand filter+SWG = Sand filter love affair!
    Don't waste time and energy looking for a better value on test kits, the TF100 is the best deal around. I did the looking and spent the extra money, but you don't have to make the same mistake. Just go here: TFTestkits. I use Pool Calculator for min/max, and shocking chlorine levels.
    Aug 2010
    Dallas, TX
    4,052
    Be sure now that you have the new kit to measure your FC and CC both. If you have CCs higher than .5, you might still have an issue that needs to be resolved.
