Thread: CSI question
    CSI question
    I am confused about the CFI numbers on the pool calculator.
    My pool: 20,000 gal. Intellichlor Salt Generator Plaster surface (new plaster 3 weeks old)
    FC 5
    pH 7.5
    TA 120
    CH 340
    CYA 70
    Salt 3400
    The CSI number on the left is -0.28 and reads "balanced"
    The CSI number on the right is -0.32 and reads "potential for corrosion"
    Why is there two numbers?
    Thanks
    14,500 gal pool
    Inground
    Water Fall
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Re: CSI question
    The number on the left is a calculation that corresponds to the now column (left most) measurements you put in for the test parameters (pH, TA, CH, CYA, Temp, Salt level, Borate level). The number on the right is a calculation that corresponds to the Target column (right most) of where you are adjusting those parameters to.
    Re: CSI question
    There are two columns, "Now" and "Goal". The number on the left shows the CSI for the "Now" column, while the number on the right shows the CSI for the values in the Goal column.
    With plaster only three weeks old, you shouldn't be worrying about CSI just yet. The TA and CH levels will continue going up as the plaster cures. If you adjust them now they will probably end up being too high in a couple of weeks.
    Re: CSI question
    Quote Originally Posted by linen
    If I adjust to the number on the right then the reading "potential to become corrosive". How do I know what number to adjust to?
    Thanks for the response.
    14,500 gal pool
    Inground
    Water Fall
    Re: CSI question
    At what point should I start adjusting for CSI? How old should the plaster be?
    Thanks Jason
    14,500 gal pool
    Inground
    Water Fall
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Re: CSI question
    Quote Originally Posted by Miscanthus
    I will let others chime in on this. Here is the pool school article: http://www.troublefreepool.com/pool-...aster_start-up
