Thread: Backwashing questions
    Martha_D's Avatar
    May 2012
    Putnam, NY
    67
    When do I need to backwash? I read somewhere something about the pressure... the pressure on my filter is around 20 right now.
    also... should the main drain valve be open while backwashing or the skimmer valve or both?
    thanks
    34K gallon, Hayward S240 sand filter, in ground, gunite... not sure of pump size and flow rate
    Re: Backwashing questions
    You backwash when the filter pressure goes up by 25% over the starting pressure. If you don't know your clean filter pressure, you might as well backwash now so you can find out what it is.
    You can leave the skimmer/drain valve(s) alone when backwashing.
    Martha_D's Avatar
    May 2012
    Putnam, NY
    67
    Thank you Jason, this brings up another question. I have been running the pump with skimmer open and main closed. Is this correct? Im not really sure what the main drain is used for...
    WestSidePool's Avatar
    Cincinnati, OH
    424
    Like Jason said, when you get your starting pressure (right after you add your filter media), you set your green dial to match the black pressure line. When the dial reaches red you know it's time to backwash.
    Eric
    IG 17x33 Grecian - Vinyl Liner (21k gallons), Hayward Pro-Grid DE 4820 filter, Hayward Super Pump, CompuPool SWG CPSC36, TF-100 Test Kit
    Typically you want the skimmer all the way open and the main drain partially open. You want the main drain at least partially open so the pump can still draw water even if the skimmer gets clogged and also so that the deep water near the drain gets circulated well. Having both on also improves the overall efficiency of the system.
    Some pools work well with the main drain all the way open, others require it to only be partially open so that the skimmer will still skim effectively. If in doubt, go for partially open.
    Martha_D's Avatar
    May 2012
    Putnam, NY
    67
    ok, thanks guys!
