Hayward S244T w/ above ground pool?
May 21, 2012
45
York Pennsylvania
Sorry if this has been addressed but I could find nothing. Is there anything that says I can not use the Hayward S224T for my above ground pool? I'm up grading from a 100 pound sand to the 300 pound sand. Or I want to. Recommendation welcome.
24x52" Round AGP
Hayward 100 pound sand 1 HP matrix pump
The 244 will be fine with your pool. The fittings on the multiport will be threaded, so you may need adapters if you use hoses on your pool, or go ahead and switch to PVC plumbing at the time.
