Thread: Hayward S244T w/ above ground pool?
    May 2012
    York Pennsylvania
    45
    Sorry if this has been addressed but I could find nothing. Is there anything that says I can not use the Hayward S224T for my above ground pool? I'm up grading from a 100 pound sand to the 300 pound sand. Or I want to. Recommendation welcome.
    24x52" Round AGP
    Hayward 100 pound sand 1 HP matrix pump
    Dave S
    24x52" Round AGP
    Hayward S244T 300 pound sand 1 HP matrix pump
    Taylor K-2005 Test kit with the K-1515-A FAS-DPD added on.
    No one is useless, you can always serve as a bad example!
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    Re: Hayward S244T w/ above ground pool?
    The 244 will be fine with your pool. The fittings on the multiport will be threaded, so you may need adapters if you use hoses on your pool, or go ahead and switch to PVC plumbing at the time.
    May 2012
    York Pennsylvania
    45
    Thank you
    Dave S
    24x52" Round AGP
