Thread: cya
    cya
    How much cya by pounds of powder should I be adding for a 22500 gal pool. I used the calculator and checked with a couple other sources and there is a big difference. One source says 40 pounds. Another says 20. Please help.
    15,000 gallon, IG Diamond Brite plaster, Hayward Max Flo 1.5HP pump, Pentair Clean and Clear 100gpm cartridge filter. http://imgur.com/xHFxE
    30,431
    Re: cya
    Did you have a problem entering the data into the calculator? If the information is entered correctly, it is correct.
    It has been verified by 1,000's of users.
    Jun 2011
    Long Beach, CA
    2,790
    Re: cya
    I'm getting 15lbs. of CYA to go from 0 to 80 ppm for 22,500 gallons. I suggest adding half the amount and test in one week, then add the right amount to get you to 80 ppm if you are running a SWG. Easier to add more, difficult to remove excess CYA.
