Thread: What does it mean when TA turns red after adding R0007/R008?
    I tested my hot tub and PH is almost clear and TA turns to red instead of green after adding 2 drops of R0007 and 5 drops of R0008. I'm guessing it mean I have no TA or PH? Bromine level shows high but I only have test strips for that, my FAS-DPD test kit doesn't test for bromine levels. I've read high bromine levels could cause wrong readings of TA and PH, is that correct?
    While researching this I added water which overflowed. I scooped out alot to get it down to normal. I added some PH and retest still shows bromine high on the strip. PH now shows a Barney the Dinosaur purple color. I retested TA and now after 2 dops of R0007 & 5 drops of R0008 the water is a bluish green. It only took one drop to get it to a reddish purple. I'm thinking I'll pull the bromine float and check it again in a few days. May be time to change the water :]
    POOL SPECS - 18' round AG pool Doughboy pool with 5'8" deep-end, Aqua Trol Salt Water Generator, 1HP Doughboy pump, Doughboy sand filter, Solar Dome cover and a 40'x4' solar heater. Located in Oregon with swimming season from end of May through September. I pull the pump & SWG during winter months. Solar Dome minimizes FC loss & keeps heat in & debris out. Btw - Solar Dome lasted about 6 years before plastic started shredding.
    Montreal Canada
    326
    Re: What does it mean when TA turns red after adding R0007/R
    When R-0008 turns red immediately, the pH is <= 4.5 and TA = 0 . You need to correct the pH ASAP.
    The FAS-DPD can test for bromine, just multiply your results by 2.25.
    High bromine can change the color of the pH reagent.
    Ok, using the above, bromine FC is at 62. I pulled the bromine dispenser and will let it get back down.
