Results 1 to 12 of 12
Thread: Deck around pool and skimmer cover?
    Jul 2011
    CT
    56
    I'm building a 4' deck around my AGP. I have the framing done except for around the skimmer and cover. I'm thinking of leaving that open with the decking coming close to it for easy access. The decking is 5/4 ipe that is going just under the top rail. I don't have enough height to cover it with a hatch.
    Anyone do something similar? I'm trying to figure out the best way to frame this out.
    I'm hoping to get the 10'x18' deck off the long side framed this week and then start the decking late this week and over the weekend.
    I hope this makes sense. If not I'll take a picture tomorrow when it's light out and post it.
    Sharkline Matrix 15x30x54, Hayward 1hp 2 speed pump, Hayward EC-50 DE Filter, Rome/Solarium 105k Heat Pump, Aquabot Rover Jr - Deceased - looking to replace it
    Re: Deck around pool and skimmer cover?
    Post a picture if you can. I had a similar situation with my deck.
    15' x 30' x 52" Oval AGP; 1hp Hayward Powerflo LX Pump; Hayward Sand Filter; 4 2'x20' Sungrabber Solar Panels; Compupool CPSC36 SWG
    cramar's Avatar
    Nov 2010
    Sault Ontario
    1,143
    Elevated hatch that sits atop the skimmer and deck??
    My concern would be people stepping on the skimmer, someone steps on it and that's gonna be bad news for the pool.
    Perhaps you could make it several inches above the deck so it's quite noticeable and safe.
    Quote Originally Posted by cramar
    Yep, that's what I ended up doing. Actually I just put a "lid" over the skimmer that I can raise up to clean the basket.
    Jul 2011
    CT
    56
    That is a good idea. I will see how I can frame it to elevate it while still giving it strength to stand on.
    Quote Originally Posted by Robl
    I just framed mine as close as I could to the skimmer. It left about a 12 inch wide opening. I built the deck so that it comes up to the pool railing. I used deck boards to make a lid with hinges to access the skimmer. I can stand on it and it's just as strong as any other part of the deck. Is your deck as high as your skimmer?
    cramar's Avatar
    Nov 2010
    Sault Ontario
    1,143
    Definitely make it strong enough for an adult to stand on it, guaranteed if it stands out people will be drawn to it like moths to a light
    Sep 2009
    Greentown, IN
    914
    We had to find a way to access our skimmer as well. Having a round pool & everything being octagonal shaped, we simple didn't screw the board down over the pool skimmer lid. It's only about 1 1/2-2 ft long and easy to manage. When the pool is being actively swimmed in and the decking gets wet frequently, the board fits snuggly but will come out with a tug. It is supported underneath just like all of the other boards, just w/o the screws into the framing underneath it. It helps too that it's on the far side of the pool where we don't get a lot of traffic, but I never fear for it to flip on someone because it does fit snuggly during the busy part of the swimming season. It has yet to bow, warp, or flex and we are starting our third season.
    Indiana, ABG 24'x52" Galveston by Blue Cascade (Craigslist buy w/part of deck included), 13,500 gallons, Intex SWG, solar panels mix 2, TF-100 test kit.
    Test kits compared
    Purchase test kits
    Jul 2011
    CT
    56
    Here's a couple pics. I think it will be easy enough to do but not sure the best way to do it. Hopefully the pictures and comments will explain enough. I'm using 5/4x3 1/2" grooved ipe w/ hidden fasteners. I like the hatch idea which I don't mind screwing from the top. Hinged would be nice.
    I think you're OK on the right side of your skimmer with the joist you have in place. You'll need some more support to the left of the skimmer though. I would put another post on the left side of the skimmer. Run a joist from that post parallel to the joist on the skimmer's left. You can lay your decking across the back of the skimmer. Just leave a space open above the skimmer and make a trap door to cover the skimmer. I built mine on top of the decking but you could build it so that it fits into the decking if you plan ahead a little better than I did. I'll take some pictures of mine for you tomorrow.
    How do you plan on laying the decking?
    Jul 2011
    CT
    56
    I think I know what you mean. How much clearance should I have from the skimmer on all sides?
    The decking was planned to fan out from the edge. The ends of the decking will be placed just under the top rail with about 1/4" clearance.
    For the winter cover I'm going to get an in-ground cover unless there is a better option?
    mcoonan's Avatar
    Aug 2008
    Mendota Heights, MN
    292
    I think you will be sorry down the lane if you do not build a box around the skimmer and put a hatch door in to access the entire skimmer. You need to be able to EASILY access the skimmer to clean it out or it will not get done as often as is should be.
    Intex Ultra 18' x 52" AG 6,981 Gal.
    3 - 2'x20' solar panels
    Hayward XStream 1500 Cart Filter
    Hayward 1-1/2 HP 2-speed Superpump
    Aquabot Pool Rover
    2-Softub 300 hot tubs (yup just got one for the lake)
    TF Test Kit Doing the BBB for 7 years
    Medota Heights,Minnesota
