Results 1 to 20 of 20
Thread: high chlorine and can't shock?
    mariane's Avatar
    May 2012
    Southeast Michigan
    291
    Thanks for the previous help. I have opened our pool, running the pump since this morning. Test results as followed:
    FC 23
    CC 2
    TC 25
    pH 7.2
    TA 90
    CH 150
    CYA 50
    My question: once I started sweeping the pool, it turned cloudy and the FC started dropping from 25 to 23, CC increased from 0 to 2, pH dropped from 7.8 to 7.2. I know to keep pool at shock level until the overnight test shows no drop in FC levels, but since FC is so high to begin with, should I just continue to brush, sweep and retest in the morning? Also, is it best to bring up the pH and TA now or wait till the FC comes down? Am I correct that shock level is 16 for CYA at 50 in a nonSWG pool, 13,200 gallon vinyl AG?
    Thank you again for this great resource.
    Mariane
    16 x 28 Doughboy Mystic Garden AGP with 7' deep end (used expandable vinyl liner) ~11,800 gals. Deep end main drain. Thru-the-wall skimmer, one return at deep end. Media Master 150# sand filter. Doughboy PowerPak II pump, 1 hp. Pentair MinimaxCH 150m natural gas heater. Polaris 65 when it feels like working . TF-100 test kit. No longer 'pool stored' 5 years and counting. In sunny but fickle metro-Detroit.
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,274
    Re: high chlorine and can't shock?
    Shock level is 20 for CYA of 50 Couple points over won't hurt either. PH readings are inaccurate over FC of 10. Hang in there!
    30,315
    Of course. Replenish the FC as often as you can but no one expects you to pull an all-nighter.
    Probably 3 times or so tomorrw is just fine.
    mariane's Avatar
    May 2012
    Southeast Michigan
    291
    Thanks again.
    No all-nighter here. ;o)
    Nite all.
    mariane's Avatar
    May 2012
    Southeast Michigan
    291
    Good morning all. Thanks again for the encouragement and advice. Did the overnight chlorine loss test.
    FYI this am test results
    FC 18 (last night was 23)
    CC 0 (last night was 2)
    pool looks clearer, brushed and then added chlorine to get back to 20 shock level. will recheck soon.
    This is sort of fun in a fulfilling way, getting a BBB sparkly pool. ;o)
    22,475
    You're headed in the right direction. Keep after it and you'll be there soon.
    mariane's Avatar
    May 2012
    Southeast Michigan
    291
    Just an update.
    Pool looks clear but FC levels dropped by 5 last night. Now this morning:
    FC 18
    CC 0.5
    TA 100
    CYA 50
    pH 7.3
    Still want to keep shock levels so added more chlorine.
    I think I'm in the home stretch. Read on another post it's okay to swim when FC levels are below shock level (which is 20). I'm hoping to be swimming on Friday. ;o)
    Had ducks swimming in pool this am. I wanted to be first in the pool, not them. ;o)
    Bama Rambler, woodyp, duraleigh, Thanks again for your help.
    22,475
    The ducks might be the reason you lost so much FC if they were in there before you ran the morning test.
    Unfortunately you'll have to keep it at shock level until it passes the OCLT regardless of what's causing the FC to fall.
    37,420
    Quote Originally Posted by mariane
    Quote Originally Posted by woodyp
    Just wanted to point out that you are both "right". The shock levels in the CYA/Chlorine chart (20ppm) are a little more conservative than the shock levels from the poolcalculator (16ppm) ... either will work, but the higher might be a bit faster.
    mariane's Avatar
    May 2012
    Southeast Michigan
    291
    Bama Rambler- ducks would explain a number of things.
    In previous years (before finding TFP and BBB, the pool was cloudy most of the summer and I know ducks have been swimming in the dirty winter cover for several years. just did not expect them to swim in the clean pool water. Who knew?! ;o)
    Next question re: shock and ducks.
    Since the ducks are swimming in the wee early morning and if the huge drop in FC is their fault, how can I keep ahead of them and not have to shock every morning, or keep pool at shock level every day?
    Thanks for the help. *I plan on buying toy snakes. My son asked if we should buy the real ones. That would keep the ducks out and ME TOO. lol
    mariane's Avatar
    May 2012
    Southeast Michigan
    291
    I've decided to start a new thread. ducks and shock levels
    Thanks for your help.
    22,475
    Let's keep it here for now.
    I'd try the snakes and see how that works.
    mariane's Avatar
    May 2012
    Southeast Michigan
    291
    Okay. Will do.
    Just took readings.
    FC 21
    CC 0
    Will see what happens overnight. Or should I get the FC level higher first so it won't fall below shock level?
    I've appreciated everyone's help. Thanks.
    mariane's Avatar
    May 2012
    Southeast Michigan
    291
    I decided to raise the FC levels last night just in case we were revisited by the ducks. (As I was writing this post, I heard ducks quacking and ran outside to check the pool. No unauthorized swimmers.)
    Last night's FC level was 24 and CC was .5.
    This morning's FC 22 and CC .5. Water is clear.
    Are we there yet?
    All your help has been greatly appreciated.
    *Fickle Detroit is not sunny today.
    Mod Squad zea3's Avatar
    Jul 2009
    Houston, Texas
    9,273
    Not quite but getting closer!
    Love TFP? Become a
    TFP Supporter!
    mariane's Avatar
    May 2012
    Southeast Michigan
    291
    Thanks zea3. I can't imagine what this would have been like if the pool started off green. ;oD
    22,475
    I really think those ducks have been most of your problem. If you can keep them at bay for a few days you should pass the OCLT. You'd be surprised how much 'stuff' they put in the water.
    mariane's Avatar
    May 2012
    Southeast Michigan
    291
    Bama Rambler
    I see what you're talking about. Also cleaning feathery stuff out of the skimmer regularly. Ugh.
    mariane's Avatar
    May 2012
    Southeast Michigan
    291
    Finally there. FC stayed constant from last night to this morning. CC minimum. No uninvited swimming guests (ducks).
    Now if it would stop raining, temps warm up, and the sun come out we could go swimming.
    Thanks for everyone's help.
    BBB.
  20. Back To Top    #20
    22,475
    Whoohoo!!
