Thread: dirt entering pool question
    If I shut off my pump and then turn it on dirt passes through my sand filter into my pool. The Sand is one season old and was bought at the local pool store. Is this normal or is the sand too course? I've put DE media in but I fear it will also pass through. I let the pressure build 25% before a backwashing. I don't like vacuuming all the time.
    Thanks Brian
    Mar 2012
    Amarillo, Texas
    341
    Re: dirt entering pool question
    Is it possible that you have a broken lateral?
    18'x48" AG
    Pentair 1 1/2 HP Dynamo Pump
    Sand Dollar Sand Filter w/ Zeobrite
    Lil Shark Vacuum System
    Hard Plumbed
    no, I checked them all ready. Good condition.
    22,550
    You can try using a skimmer sock all the time. That and DE in your filter are your best bets. Unless of course you want to change to a DE filter.
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    Quote Originally Posted by bribri
    Thanks Brian
    Tell us about your pool and equipment.
    The fact that pressure builds sounds like your filter is doing its job. That means the dirt probably isn't actually passing through the sand, but may be bypassing it when the water above the sand gets dirty while the pump is off, then sneaks through the multiport when the pump comes back on. I'd think that an issue with the riser pipe or it's connection at the top could cause a surge of dirt when you turn the pump on
