Thread: Ken's Simpel Pool App
    Tonight I measured my TC at 10.5 and CC at 0.5. This puts my FAC at 10. Simple Pool has my range at 4 - 8 and said I was within range. Just for kicks, I input measurements of 20, 30, 40 and so on, all the way to Simple Pool's max of 80 and the advice section still said I was within range. Huh???
    Pool: IG 22k- 16x32 clipped corners- vinyl liner, w/ a great board. Built in 3/99, new to me 2/2011.
    Equip: Hayward 3600 DE filter, Hayward CL-200 Chlorinator (empty since 7/5/2013).
    K-2006 Test kit with Speedstir
    Located in Cincinnati, OH. TFP lurker since 9/2011, BBB interested since 5/2012 and converted 7/2013.
    Re: KEN'S SIMPLE POOL APP
    Perhaps you should contact the author of Simple Pool directly.
    MattM's Avatar
    Jul 2011
    San Diego, CA
    299
    Re: Ken's Simpel Pool App
    I use simple pool, and it always says your FC is in range if it is above the minimum specified level (does not check max, perhaps because it just assumes one is shocking). I don't find this much of an issue, and nearly all the other chem checks seem to work fine.
    24K gallon inground gunite/pebble sheen pool, 34'x16' 4-7.5ft deep, 750sq ft solar, pentair ultratemp, intelliflow vs+, ic60, intellichem w/ acid pump, quad de 100, intellibright 5g, intellitouch i5-3s with Screenlogic2, 3" primary piping - 2.5" at equip pad, auto switched deep heating and main returns, automatic safety cover w/ electronic lock and embedded recessed undertrack, sealed stamped concrete deck, dolphin deluxe 5, started up December 2011.
    kenmar's Avatar
    Apr 2009
    Schnecksville, PA
    288
    Currently, SimplePool does not provide any specific advice when you measure chlorine levels above the calculated max/target level.
    I have just modified the program to state:
    "Your current FC level is too high. do not add additional chlorine. Your FC level will fall over time."
    This update will be rolled into the next release.
    Thanks for pointing this out.
    -Ken-
    20'x40' / 30,000 Gal / In Ground / Vinyl
    Pentair FNS 48 DE Filter / Pentair Challenger 1.5 HP Pump
    Jandy Lite2 400k BTU Propane Heater / Dolphin Dynamic cleaning robot
    TF-100 Test Kit / BBB
    Creator of SimplePool (BBB Friendly Android App) http://www.simplepool.net
