Thread: problem with steps--Help!!!!!
    poolmama67's Avatar
    May 2012
    Arkansas
    209
    I have an above ground pool. We recently had a deck built. I attached my steps to my deck and now I have a space about 4 "-5" between the bottom of the steps and the bottom of the pool. Any suggestions as to what I can place in that space.
    24 ft. round ABG-vinyl-15200 gallon
    Sand Filter w/1 1/2 HP pump
    Installed May 2011
    Taylor K-2006 test kit
    BBB method
    http://www.poolcalculator.com/
    pool-school/chlorine_cya_chart_shock
    pool-school/shocking_your_pool
    pool-school/pool_test_kit_comparison
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Re: problem with steps--Help!!!!!
    Welcome to tfp, poolmama67
    Could you post a picture?
    You may need longer steps, or you may want to get steps that do not need to sit on the bottom.
    poolmama67's Avatar
    May 2012
    Arkansas
    209
    Was able to adjust the handles on the steps.
    Installed May 2011
    BBB method
    Sep 2009
    Greentown, IN
    914
    Glad you found a simple solution. Pool steps can be expensive!
    Indiana, ABG 24'x52" Galveston by Blue Cascade (Craigslist buy w/part of deck included), 13,500 gallons, Intex SWG, solar panels mix 2, TF-100 test kit.
    Test kits compared
    Purchase test kits
