Thread: Rain Water
    Sep 2007
    Guelph, Ontario, Canada
    58
    Rain Water
    I find that in the heat of the summer, I am adding about 1" of water to the pool every week.
    This year I'm expecting watering bans due to the low water level.
    Has anyone given any thought to directing rain water into the pool.
    I have a shingled roof, with a downspout close enough that I could gerryrig something up.
    I was thinking of a redirecting down spout through a screen into a large pail, then using the overflow from the pail routed into the pool.
    The sediments etc from the roof would be caught in the screen and pail.
    It would likely mean my pH would stay down without adding acid.
    Would it be worth it?
    Carl Schnurr
    Pool: 96,000 litre, vinyl liner, 1 HP pump, sand filter, Aqua-rite SWG, Hayward e.vac, installed 2005
    Spa: La-Z-Boy 'Relieve', 1300 litre, acrylic, with ozonator, installed 2017
    Test Kit: Taylor 2005C
    Oct 2011
    New Caney, Texas
    414
    Re: Rain Water
    There are a few users that do just that, but I cant recall the threads
    18' x 42" Intex (4786 Gal @ 80% capacity) Intex 8110 SWCG, 2000 GPH cartridge filter.
    Full Sun, Well Water, Borates at approx. 50
    TFTestKit-100--The Pool Calculator--Pool School
    37,399
    Re: Rain Water
    There certainly are people that do that ... I think to help reduce CH levels. Your setup sounds pretty good to avoid the debris off the roof (like parts of the shingles) from getting to your pool.
    Smykowski's Avatar
    Sep 2011
    3,065
    Re: Rain Water
    Richard320 gave me the idea, and I'm using cheap panty hose on the end as my filter to keep the shingle crud out of the pool. Here's his threads...
    to-drain-or-not-to-drain-t41304.html
    finally-some-rainwater-dilution-t28006.html
    My setup isn't quite as effective because the closest downspout I could connect to doesn't get a huge area of the roof. (Also, Murphy's Law of pools, the day before I set up the tubing was the last day of any serious rain, and it's been a couple of weeks.) I can't comment yet on success or not, but I'm giving it a shot.
    Jul 2011
    Limerick, PA
    28
    Re: Rain Water
    Sportsman's Guide has rain barrell collectors with a hose port at the bottom. You can run a hose directly to the pool. Just do a search on their site - they have a number of options.
    17x39 Rectangular, 20,000 Gal, Plaster, Pentair Easy Touch Automation and Remote
    Pentair WhisperFlow 2 hp pump with Pentair Clean & Clear Cartridge Filter
    Pentair Master Temp Gas Heater, Pentair IntelliChlor IC-40, Pentair Kreepy Krauly Legend II Cleaner
    ..and one frog that thinks the pool is his.
