Page 1 of 2 12 LastLast
Results 1 to 20 of 26
Thread: Newb Planning to Clear a Green Pool
    May 2012
    Houston, TX
    17
    Hello, guys. I should first say thank you for being here for newbies like me & my husband. We are new pool owners (~2 months) & know absolutely nothing about pool care! But I am working on changing that & have been staying up til 2 or 3AM x 3 (or is it 4?) days, immersing myself in the pool school.
    We have been enjoying our pool until it rained for a couple of days last week. The water just kept getting murkier & is now a solid, sickly green!
    I had the water tested at a local pool store. Results as ff:
    CYA 40
    FC 0.6
    pH 8.1
    TA 78
    CH 125 (calculated fr TH 188)
    After all the late nights educating myself, I have come up w/ a plan. I would appreciate any feedback. I think we may need a little handholding...ack! I should say, I KNOW we need a LOT of handholding, so please bear with me if (& when) I ask seemingly stupid questions. So, here goes:
    1) Order TF100 test kit - DONE
    - Question: Should I wait for the test kit to arrive? In all honesty, I would rather start this
    today, this evening.
    2) Stock up on supplies - DONE
    5 cases of 3/182oz per case of Bleach 6%
    2 gal Muriatic Acid 31.45%
    1 pk (6.12kg) Arm & Hammer Pure baking soda
    - Q: Do I have enough to see this through?
    3) Clean filter, skimmer, pump baskets. - DONE
    4) Turn pump on 24/7.
    - Q: Since I have a VSP, what speed should I keep it at? Right now it's as ff:
    Speed 1 - 85% - OFF
    Speed 2 - 65% - 9am - 1pm
    Speed 3 - 45% - 1pm - 5pm
    Speed 4 - 35% - 5pm - 9pm
    -Q: Do I also keep the sheer descents & swim jet turned on?
    5) Adjust pH level from 8.1 to 7.2. Using the pool calculator, I will pour 42oz of Muriatic acid on the deep end, near a return.
    - Q: How soon can I test the pH? I will be using aqua check strips my PB provided
    until the test kit arrives...
    6) Do I also need to adjust TA before shocking? If so, do I do this before balancing pH? What TA level should I go for for my pool?
    7) SHOCK! SKIM! SHOCK! BRUSH! SHOCK! BRUSH!
    - With a CYA 40, my shock level is 15, I will pour 3 jugs of 182 oz of bleach, wait 1 HR, repeat. And brush the heck out of the pool during wait times.
    -Q: If I'm doing this w/o my test kit, do I pour the same amount every hour on the hour
    until pool water is clear? I have enough bleach to do 5 cycles tonight. Then have water
    tested in pool store twice a day, early AM & evening, that is until my test kit gets here &
    adjust shock levels accordingly.
    - Q: Should I turn the chlorinator off while doing all this?
    8) Repeat until an overnight FC loss test <1ppm.
    9) Clean filters, skimmers, pump baskets as necessary.
    10) Balance water chemistry.
    11) then
    Sorry for a long first post, but as you probably can tell, I'm itching to get started!
    LeiA
    Husband & Wife team from Houston, TX
    18k, IG pool, w/ pebblesheen
    Hayward Ecostar 1hp variable speed pump (for pool)
    Hayward Super II pump 2hp (for sheer descents)
    Another (?) pump for swim jet
    UltraPure Ozonator
    Swimclear Cartridge filter
    ProLogic Control
    Feb 2012
    Phoenix, AZ
    728
    Re: Newb Planning to Clear a Green Pool
    Hello and welcome to TFP!
    I can tell you have done your research, and it is nice to see a new member that is so well-prepared!
    You COULD start adding chlorine now..but the TF-100 kit ships very fast, and shocking will be much easier and efficient when you have that kit.
    It is tough to say if you have enough chemicals on hand (because the chlorine consumption will vary, as well as the time it takes to complete the shock process)
    You are, however, well stocked for a great start!
    Lowering pH with Muriatic Acid will also bring TA down.
    You won't add the same dose of chemicals every hour..you will test the water, then use pool calculator to get the proper dose (and bring FC back up to shock level)
    Yes, you can turn off your SWG. (and you should have SWG off when you get close to finished and do a OCLT)
    kenmar's Avatar
    Apr 2009
    Schnecksville, PA
    288
    You are going to have the most sparkly pool in the neighborhood!
    Welcome!
    20'x40' / 30,000 Gal / In Ground / Vinyl
    Pentair FNS 48 DE Filter / Pentair Challenger 1.5 HP Pump
    Jandy Lite2 400k BTU Propane Heater / Dolphin Dynamic cleaning robot
    TF-100 Test Kit / BBB
    Creator of SimplePool (BBB Friendly Android App) http://www.simplepool.net
    38,251
    1)
    2) May need more bleach, but just get more when running low. May not need the baking soda at all at this point.
    3)
    4) Not sure, but I would think 35% would be fine overnight and easiest to program
    5) Have to get pH in the low 7s before shocking as the test is not valid for FC > 10ppm. Generally need up to around 60 minutes of circulation to re-test
    6) Ignore TA until after shocking ... around 80ppm is not bad anyway
    7) Q1) Going to be hard before you get the test kit. You need to retest the FC every hour and then recalculate how much to add each time to get back over your shock level. You could put the 3 jugs in the first time and then just add a jug each day until your kit comes in , but it is all kind of a guessing game
    Q2) What chlorinator? Is it pucks? Those would be adding CYA which is BAD.
    8) and CC < 0.5 and water is clear
    9)
    10)
    11)
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,569
    In all honesty, you should adjust your PH.........adjust your Ta..............and sit back and scratch your itch till your test kit arrives. Guessing at what level your shock level is at and how much you will need to maintain it until then is exactly that--a guess. It could very possibly save you time, frustration, and money just to wait so you KNOW how much of what to add. You'll get there! WELCOME!
    May 2012
    Houston, TX
    17
    Thanks for all the feedback! Is my OCD getting apparent? :P
    Yes, I know we have the trichlor pucks. I believe that's why we have this algae prob now 2mos into using it. One of the things in the near future I need to address.
    I understand the downside to doing it the guesstimate way. My concern was if I would wait 2-3 more days before my kit gets here, the pool might have too much algae & approach radioactive levels!!! Then I would have to use more chlorine, or worse (as I'm assuming there is something worse?! ), thus my urgency to get it started. But if the consensus is to wait, then wait I shall. What would be a good TA level for me, considering I was on tricolor pucks?
    Any thoughts on what I need to do for the sheer descents & swim jet? Turn it on? Or it doesn't matter?
    And Kenmar, I should hope so! That's the ultimate goal!
    LeiA
    UltraPure Ozonator
    ProLogic Control
    22,543
    Just jumping in here to say you have definitely done your homework.
    I'm in the wait on your kit crowd. In Houston it'll take about 3 days for it to get there.
    One reason I say wait is that the pool store says your CYA is 40 ppm but you've been using pucks and the CYA test is one that they're the worst at getting even close.
    My suspicion is that you're going to need more bleach so I'd use this time to get a few more cases.
    gboulton's Avatar
    Apr 2012
    Nashville, TN
    380
    I too must jump in just to say how awesome it is to see a new member so thoroughly prepared. All the information's here, and clearly you've availed yourself of it!
    Also agree with waiting on the kit. There's simply no substitute, no matter how much we empathize with wanting to get started. Test strips and pool store results will simply leave you guessing how far off they are, and that's WORSE than doing nothing. As others have said, you'll have the TF-100 with a quickness.
    Looking forward to watching this process. Take before, during, and after photos...we love those!
    -Gordon
    Pool School helps me maintain my 13,500G 24' x 48" ASP with Sand Filtration using a TF100 Test Kit and Pool Calculator.
    Remember, the Shock Process should be followed until : 1. CC is less than 0.5 ppm, 2. An OCLT shows a loss of 1.0 ppm or less and, 3. The water is crystal clear.
    --I didn't buy my pool to swim in it. I bought my pool to watch my wife swim in it. :wink:
    May 2012
    Houston, TX
    17
    Hello, all! Last night my husband changed the pump setting to run 24/7, hi speed @ 85%. Well, I woke up this AM, intending to take those pictures (cringe!) & was surprised to see that the water is actually looking blue, not the swampy green it was. Still dirty, murky, & can't-see-the-bottom blue but blue. So, I asked my hubby if he's done anything different last night (after deciding to wait for the kit, I was dead to the world last night ; guess it was from the all nighters reading! ).
    Anyways, he read my notes on THE plan (I did admit to the OCD, didnt I?) on the pool binder (yes, I created one) & he carried it out! Yikes! He said he started with the 3 jugs of bleach, then thinking 3 jugs every hour was "overkill", followed it w/ 1jug every hr, 2x last night, then another 1 very early this AM. He said he brushed REALLY hard, that he was as slick as a greased weasel....well, I won't finish what he said. (I guess my exclamation points on the brushing got to him). He did test using the strips before dumping the next jug but he said "I dont know what ur looking for coz the colors look all the same to me all through out". Oh, bless his well-intentioned heart. I sent him fishing so I won't have to drown him & my kids will witness me doing in their papa!
    My question is, until the test kit gets here, what do I do now?
    LeiA
    UltraPure Ozonator
    ProLogic Control
    38,251
    No harm done.
    I would think you could continue to add a jug or 2 spread out over each day (especially at night so the sun has no affect) to just keep a little chlorine in the pool and then hit it hard and accurately when the test shows up. You may end up using a little more bleach this route since you are probably not hitting the shock level for FC, but adding a little will help slow the regrowth of any algae.
    22,543
    X2 what JB said!
    May 2012
    Houston, TX
    17
    Whew! Alrighty, then. Thanks, guys.
    UltraPure Ozonator
    ProLogic Control
    Sep 2009
    Greentown, IN
    914
    Welcome! You have certainly done your homework...Awesome!
    I understand your feeling of urgency, you will be there in no time. This forum is great and I think you already have a good handle on the process.
    You're going to have an amazing sparkling pool your friends will be jealous of!
    Indiana, ABG 24'x52" Galveston by Blue Cascade (Craigslist buy w/part of deck included), 13,500 gallons, Intex SWG, solar panels mix 2, TF-100 test kit.
    Test kits compared
    Purchase test kits
    May 2012
    Houston, TX
    17
    Hello, guys. So I finally have my test kit (delay was totally my fault ; it got delivered to the neighbor. Thankfully they handed it to me Saturday, May 26th). Anyhow, with that weekend being Memorial Weekend, the family wanted to have a pool party so the I didn't get to shock til last night. Pumps on 24/7 & puck chlorinator off. Pls let me know if I'm missing something or anything I'm not doing right.
    My initial test readings are as ff:
    May 29 @ 7:30pm
    pH 7.2
    FC 6
    CC 1.0
    TA 80
    CYA 30 (re-checked 3x)
    CH 160
    @ 8pm
    - Poured 1.4 jugs of 182oz clorox 6% to raise my FC of 6 to 13 (shock level).
    - Pool skimmed
    @ ~9pm
    - FC 10
    - Poured 112oz of clorox 6% (I bought a painter's cup w/ measurement readings just for this purpose )
    - Pool brushed
    @ ~11pm (I know I was late testing; the kids just wouldnt stay in bed! sigh!)
    - FC 20 - huh?!?! what happened here? It took 40 drops before the pool water cleared! Since it was late, I decided to sleep it off & continue shocking in the AM.
    May 30 @ 9AM
    - water clear
    - FC 17
    - CC 0.5
    - Skimmed & brushed
    Will test FC again this evening, bring it up to shock level one more time, then do the overnight test tonight. Feedback, pls? Just wanna make sure I'm doing this right. Thanks, guys!
    Oh, and I wanted to attach pics but the file was too big? Suggestions from the tech gurus on how to alter so I can upload??
    LeiA
    UltraPure Ozonator
    ProLogic Control
    gboulton's Avatar
    Apr 2012
    Nashville, TN
    380
    From what I see there, you couldn't be doing it MORE right!!
    Water's clear, CC is down. If those two things stay as they are, and you pass the OCLT tonight, then pat yourself on the back and go swimming tomorrow!
    -Gordon
    38,251
    You can either put the pictures on photobucket or something like that and post the link here.
    OR
    Resize the pictures using Microsoft Picture Manager or the software from your camera and post them directly here.
    Administrator Leebo's Avatar
    Jul 2011
    Eastern Ohio
    7,077
    I'm lost.....why do you need us again??
    May 2012
    Houston, TX
    17
    Re: Newb Planning to Clear a Green Pool - ACHIEVED!
    Howdy, guys! Passed the OCLT! Yippee!
    Couldn't have done it without the invaluable info & tireless guidance from you all! So, don't let me fool you; all I did was read & apply the FREE info & advice. TFP RULES!!!
    My numbers:
    @ 8pm, FC = 12; brought it up to shock level one more time @ 13; brushed & skimmed
    @ 10pm, FC = 13
    @ 6am today, FC = 13
    CC = 0.5
    water clear
    Hubby will clean the cartridge filter today.
    So, now to maintain the pool, I do the basic ph/chlorine test daily? The FC/CC weekly (or as necessary if pool is not looking clear, after pool parties, rain); and the rest of the tests monthly?
    Would these target levels be okay??
    pH = 7.5 (I have a return in the tanning shelf that aerates the pool everytime pump is on & also have sheer descents)
    FC = 5 (The pool gets ~10 hours of sun; I have no pool cover)
    TA = 80 ?
    CYA = 30 (we have a month long vacation coming up next month & I'm planning on using the trichlor pucks while we're away)
    CH = 200 ? (from 160, for a gunite pool)
    The pump is still on 24/7. How soon can I turn it down? What would be a good pump run time for my pool, variable speed?
    Again, thank you! Wish I could invite you all to our pool parties!
    LeiA
    P.S. I'll post pics as soon as I figure this out (we have a Mac). This is more frustrating than getting the pool sparkly! LOL!
    UltraPure Ozonator
    ProLogic Control
    Feb 2012
    Phoenix, AZ
    728
    Those numbers look GREAT! Congratulations and great job!
    Only thing I might change is CH..you could be in the 250-350 range
    As for posting pics, here is a visual guide I put together: how-to-add-pictures-to-a-post-full-guide-with-screenshots-t45050.html
  20. Back To Top    #20
    gboulton's Avatar
    Apr 2012
    Nashville, TN
    380
    Enjoy your sparkly clean water!
    -Gordon
