Thread: Cartridge filter selection
    Hi, looking at upgrading my cartridge filter to something along the lines I a 300 ft model and see that jandy, Hayward and pentair have filters in this size.
    Is one brand really any better than the other?
    Also while I am at it should I look into possibly switching to a sand or de filter? Any benefit to switching?
    Let me know and thanks,
    18' x 33' Aqua leader AGP (~19k gal) w/hayward swimpro voyager cartridge filter and 2hp hayward pump.
    8 Gal LQ, hayward heater.
    Feb 2012
    Phoenix, AZ
    728
    Re: Cartridge filter selection
    All of those brands will work just fine. As far as setting the new one up, it would be smart to get measurements from your current filter, and compare to measurements of potential replacements. You should measure the distance from the ground to the center of your filter outlet. Also, get the center-to-center measurement between the inlet/outlet. These measurements don't have to match exactly with your new filter, but good to know what type of plumbing will be involved in the swap.
    As for other filters, here is some general info about the different types:
    A sand filter will filter down to 40 microns, and require back-washing somewhat regularly
    A cartridge filter will filter down to 10 microns and cartridges are cleaned manually (no backwashing)
    A DE filter will filter down to 5 microns, and require back-washing (less often than sand)
    mcoonan's Avatar
    Aug 2008
    Mendota Heights, MN
    292
    Along with the cost of the filter, check on the price of the cartridges. Some can be alot more than others.
    Intex Ultra 18' x 52" AG 6,981 Gal.
    3 - 2'x20' solar panels
    Hayward XStream 1500 Cart Filter
    Hayward 1-1/2 HP 2-speed Superpump
    Aquabot Pool Rover
    2-Softub 300 hot tubs (yup just got one for the lake)
    TF Test Kit Doing the BBB for 7 years
    Medota Heights,Minnesota
    I am starting to lean toward pentair, it's seems like the replacement cartridges are more readily available online than the Hayward in that size.
