Thread: Help treating my pool!
    Hello all, I'm newish to having a pool. I had this one last summer and didn't have any problems but now I have one and the pool store here is useless. Me being lazy i never put up my pool over the winter so it had standing water in it about 3-4 in all thru the winter (yea i know bad move) and about a month ago I decided to clean it up and try to get it ready for this summer. I sprayed down the entire inside with a all purpose cleaner made for pools to get off stains etc. and i scrubbed it all really well. after filling it i shocked it and added a chlorine tablet and let my filter run all day. When i got up the next day my pump wasn't pumping anymore it sounded like it was full of air. I checked the filter and it was 50% filled at the bottom completely of this yellow spongey material. When i looked at the top of the water it was completely full of this little itty bitty white floaty stuff that wasn't even 1/4 inch long in most cases. but it only floated on the top of the pool. so i rinsed off my filter and ran it some more. the next day there was less of a floatie problem but the filter was full again. so i took a water sample down to the pool store and they ran it. My water was a little hard and needed chlorine and a ph minus. The lady there thought it could just be because my water was hard. So i came home and treated it with everything they wanted me too and now the floaties have went away a lot but they are still there and my filter can run for a week now and only be 1/10th full now. My question is if anyone knows what it could be and what i can do to take care of it. I asked today at the store and the lady thought it could be white water pool mold but from looking at pics online i can't be sure. any help will be very helpful!! I can't submit pics of my filter cause i thru it out today before i got online
    30,000 gal. Igp, gunite, Indoor pool
    38,475
    Re: Help treating my pool!
    Welcome
    First what you did was not "shocking" the pool. Here shock is a verb and not a noun. You have to raise the FC level to the shock level for your CYA level and then hold it there until your pass the 3 tests to stop shocking. Read Shocking Your Pool and then continue to read Pool School (button at upper right of the page) if anything I said does not make sense to you.
    BTW, a good test kit (recommended ones in my signature) will be required to successfully maintain your pool and avoid the pool store "advice"
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,052
    It's not hopeless.
    Spend some time in Pool School.
    Spend some money on a test kit - it will pay for itself, no doubt about it.
    And here's a couple threads I bookmarked for such occasions as this, when someone needs some inspiration
    thanks-tfp-swamp-to-swim-in-12-days-t38593.html
    before-and-after-t38780.html
