Thread: Plaster blisters after drain/refilll?
    Jul 2011
    Dallas, TX
    33
    So Friday night, I drained about 75% of my pool due to high CYA levels. After it filled up (took about 17 hours to fill back up) I noticed a few blisters in the plaster which broke open when I touched them. I noticed it on my top step and a few additional ones on the bottom of the pool. Did this happen because I drained the pool? Are those spots problems other than cosmetic?
    Thanks!
    Pool newbie. 25k gallon in-ground plaster pool with DE filter. MX8 and PoolSkim
    Butterfly's Avatar
    South Carolina
    10,045
    Re: Plaster blisters after drain/refilll?
    Welcome to the forum
    Can you post a full set of test results of water before you drained the pool?
    How old is the pool? Was it ever painted?
    You're done SLAMing when:
    Jul 2011
    Dallas, TX
    33
    I don't have all the numbers handy but they were all in good range except my CYA was at 160. Its now at 50. I have owned the house for two years and don't have any past info on the pool. The plaster looked fine before I drained the water over the weekend. I am running the full set of TF100 tests tonight but water looks great after the refill and I just ran the CYA test after the refill to make sure the drain worked.
    Thanks!
    A photo of some blisters would be a big help.
    Jul 2011
    Dallas, TX
    33
    Ran my first test after refill (only added bleach)
    PH- 7.5
    FC- 16
    CC- 0.5
    TA- 120
    CH- 350
    CYA- 55
    Levels look ok?
    I will see if I can post some pics of the plaster blisters. Can't seem to post photos from my iPhone so I need to send them to my computer.
    Thanks everyone!!
