Thread: FINALLY!!!!!!!!!!!! It's ALIVE!!!!
    May 2012
    Gulfport, MS
    59
    After 1 full day of setting the verticle support blocks, which I must add are (+/- .125" over 30'), we started putting water in Sunday...The J-hook liner was a snap to install, went right in. So now I am waiting to get enough water in to turn the pump on and testing the water!
    30'x54" Round Vogue Simbio AG ~21,000 gallons
    Pentair Sand Dollar SD 60 w/ Pentair Dynamo 1.5 hp Pump
    Vinyl Uni-Bead 25mil Liner
    Perfect Bottom w/cove
    Taylor K-2005 & K-2006 Test Kit
    May 2011
    Hardy, Virginia
    61
    Re: FINALLY!!!!!!!!!!!! It's ALIVE!!!!
    Congratulations!! It's always exciting to get a new pool up and running!!
    15' wide x30' long x 4.5' deep vinyl above ground, 13,500 gallons, hayward dream line sand filter, hayward power-flo lx pump 1.0 hp, lil shark cleaner
    gboulton's Avatar
    Apr 2012
    Nashville, TN
    380
    How hard was it to install the dog?
    -Gordon
    Pool School helps me maintain my 13,500G 24' x 48" ASP with Sand Filtration using a TF100 Test Kit and Pool Calculator.
    Remember, the Shock Process should be followed until : 1. CC is less than 0.5 ppm, 2. An OCLT shows a loss of 1.0 ppm or less and, 3. The water is crystal clear.
    --I didn't buy my pool to swim in it. I bought my pool to watch my wife swim in it. :wink:
