Thread: One of the blocks broke under the leg :( what now?
    SuzyAbbott's Avatar
    Dec 2011
    Hamilton, NJ
    127
    Any thoughts on how to fix a broken block under one of the legs of the pool? that corner has dropped now and I'm worried that it's putting too much pressure on that corner of the liner. the other corner is filled to the bottom of the white band around the liner, the corner that dropped is to the hole where it would overflow. should I be freaked out? any easy ways to fix it???
    Thanks!
    Suzy
    24' Sharkline Matrix. Coral Reef Liner. Clearwater II Cartridge Filter. Saltron Retro Salt WaterGenerator. 4x20 Ecosaver Solar Panels, Rover Jr. robot vac. Fiberglass Steps and Lifesaver pool fence/gate.
    Previous pool: 9x18 intex with salt water generator and vinylworks 5x10 deck.
    mcoonan's Avatar
    Aug 2008
    Mendota Heights, MN
    292
    Re: One of the blocks broke under the leg :( what now?
    Jack it up ( http://www.levelgroundpool.com/images/jack-up-pool.JPG )
    and replace the block.
    Intex Ultra 18' x 52" AG 6,981 Gal.
    3 - 2'x20' solar panels
    Hayward XStream 1500 Cart Filter
    Hayward 1-1/2 HP 2-speed Superpump
    Aquabot Pool Rover
    2-Softub 300 hot tubs (yup just got one for the lake)
    TF Test Kit Doing the BBB for 7 years
    Medota Heights,Minnesota
    racerboy6996's Avatar
    Aug 2010
    Albemarle, NC
    103
    which pool do you have?
    Intex 16ftx32ftx52in rectangular / Hayward 2 speed pump / Hayward 21in sand filter / Intex SWG / still saying solar panels coming next year
    SuzyAbbott's Avatar
    Dec 2011
    Hamilton, NJ
    127
    9x18 ultra frame.
    Aug 2010
    Albemarle, NC
    103
    i dont know about that size, but on my 16x32 I was unable to jack it up due to the weight of the water. Even with it down to only 1/4 full. If the block was in the center you could probably get away with draining a portion of your pool. Also with the design of the liner on the rectangular intex pools, it is very hard to find a spot where jacking up the pool wont rip the liner
    Unfortunately you may wind up draining it almost completely. That is what happened to me. But in doing so I was able to work slower & fix the area properly instead of being in a hurry because of the pool being jacked up.
    mcoonan's Avatar
    Aug 2008
    Mendota Heights, MN
    292
    I will have to agree with Racerboy, I thought that I had seen that it was a round Intex (brain drained).
    Aquabot Pool Rover
