Backwash
Unless there is some strange circumstance, there should be no reason to have to change the sand.
You can do a thorough cleaning by opening the top and running a hose gently down in the sand and allow the junk to flow out the top of the filter.
The sand was changed out 4 years ago according to the previous owner. May not do it since I am debating about switching out the filter next year. It as a Pac-Fab Super Flow PF-50. It looks like it has some years on it but if it works fine maybe I don't need to.
No reason at all to change 4 year old sand unless there are problems.
If it is working to your satisfaction there is no reason to change it. Hard to say if a newer one would do a better job ... I kind of doubt it as there really is no "advanced technology" involved in a sand filter :)
That filter's a little small for a 25,000 gallon pool but, as said earlier, if it's working there's no hurry about changing it out. It's obsolete so it's a good thing to be looking and deciding on what you want so when it finally goes you'll be ready to replace it.
Bama Rambler said:
Why are they changing the sand?
They will need to rinse the sand which is going to use some water, but not as much as a backwash would use. I'd raise it a little bit.
Backwash hose. Using search to find a hose/pvc to use for the Backwash outlet on a Intext 14", 1.6 gph Sand Filter. Can you direct me. Thxs!
