Thread: algae out of the pool
    Jul 2009
    Massachusetts
    188
    i have a swampy mess, and i'm working through it (12% bleach, brush and eventually vacuum once the water clears up more) - pool store recommended mustard algaecide, based on my simple response "yes" to the question "is your pool green?" I didn't buy it, since I've never added algaecide after opening and just relied on bleach.
    but, my question is about all the algae that i'm getting out of the pool. I'm running my pool robot, just to try to get some extra help removing the algae, but I'm curious about algae that ends up on my pool deck (stamped cement) and the algae that I wash off the vacuum into the grass.. do I need to be concerned with that stuff, or will it just die off once it's dried?
    thanks,
    patty
    25,000 gallon gunite pool with waterfall (built 2000 - owner as of 2009), Aerotemp / Aquacal heat pump AT12000-A, Hayward DE4800 Filter, AOS UST1202 Motor, Hydro-King T104P201 Timer, Meyco pool cover, Pentair Model 320 Auto Chlorine Feeder. Located in Massachusetts.
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    Re: algae out of the pool
    There is algae everywhere, constantly entering your pool. When you get what's already in there killed and maintain sufficient chlorine, it won't be able to get started in the pool again.
