Thread: Pool Pump or Motor replacement help??
    Hey,
    So I have a Whisperflo WF-28 pump and the motor is shot, it turns on then overheats and shuts off. Now I'm just confused should I replace the whole pump $400+ or just the motor which can be around $250+ ? The pump and pool is about 6 years old.
    Thanks
    In-ground plaster pool, sand filter
    22,549
    Re: Pool Pump or Motor replacement help??
    If there's nothing wrong with the wet end, I'd go for just replacing the motor. The wet end should last a long time just pumping pool water.
    Sounds good, thanks for clearing that up!
