Page 1 of 2 12 LastLast
Results 1 to 20 of 21
Thread: New pool owner of Intex quick set 12x30, first chemicals?
    I just filled up our new intext quick set 12x30 yesterday and need to know what chemicals to start off with. I read that you should put in shock treatment how many of those little bags should I use and do I have to put anything else in there? I was going to buy the 3 inch tabs and put them in the floating device or do you think I should use plain old bleach instead?
    Jen G
    Mar 2012
    Amarillo, Texas
    341
    Re: New pool owner of Intex quick set 12x30, first chemicals
    Jen, you need to test your water first. If you want to do the BBB method and save lots of money and frustration you don't need the bags of shock or the 3" tabs.
    18'x48" AG
    Pentair 1 1/2 HP Dynamo Pump
    Sand Dollar Sand Filter w/ Zeobrite
    Lil Shark Vacuum System
    Hard Plumbed
    That is good news, I like saving $$! Can I get a test kit at my local superstore and be okay? Thanks!
    Jen G
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    This is a good place to start: http://www.troublefreepool.com/pool-...ary_pool_guide
    See recommendation in that doc for test kits.
    Mar 2012
    Amarillo, Texas
    341
    I wouldn't buy one at your local superstore as they don't test fc at high enough levels to be useful. Buy the recommended ones and you'll be better able to maintain your pool. The initial expense might be twice what your superstore is, but your ability to maintain your pool will be simplified. As they say, knowledge is power.
    18'x48" AG
    Hard Plumbed
    Okay I can order one online but it might take a few days to get it. In the meantime since I just filled the pool should I put something in it so it doesn't go bad? Or will the cheapo test kit be okay for now until I get the good one.
    Jen G
    Mar 2012
    Amarillo, Texas
    341
    I would add at least 2ppm liquid bleach until your test kit arrives daily.
    18'x48" AG
    Hard Plumbed
    I am trying to figure out how much is 2ppm as I am new to being a pool owner. Once I get it down, I will be good to go and thanks for everyones help! I tried to use the calculator but couldn't figure it out. I have the 12x30 intex easy set round pool so how many bottles of bleach (getting them from aldi) would 2ppm be?
    Jen G
    22,551
    Your pool is about 2500 gallons. That means that 2 ppm FC will take about 10 oz of 6% bleach.
    Okay I tested the pool water I just put in last night. I just need help getting going here.
    Results:
    PH=7.8 (highest color on the scale)
    Chl=<1 (water color clear)
    I added one pack of the pool shock after reviewing the temporary pool guide. Is that the right thing to do? And then I just do that for the next few days?
    Jen G
    After re-reading the temp pool guide, it said to buy 1 pound of pool shock which I did. But what I didn't realize is that you are to split that up into four days! I put the whole bag in there on the first night...did I really mess up?!
    Jen G
    Mar 2012
    Amarillo, Texas
    341
    No, not unless it really boosts your CYA level which I wouldn't worry about since it's the first fill of a new pool. I wouldn't keep adding powdered shock. I would use bleach. Your FC levels will drift downwards as your pool is exposed to sunlgiht.
    18'x48" AG
    Hard Plumbed
    JesseWV's Avatar
    Apr 2011
    North Central WV
    526
    According to the PoolCalculator adding 1lb of Dichlor to a 2500 gal pool would raise FC by 27, raise CYA by 24 and lower pH by 1.
    You are now over 2x shock level (12ppm) and have a decent amount of stabilizer. This should buy you plenty of time until you receive your test kit.
    Once you get the kit, do a full test and post the results here. Only then can we help with the next steps to balancing your water.
    Meantime, I would not allow anyone two swim until FC is below 12 and definitely don't add anymore powdered "shock" product. Just one more 16oz bag would put you close to the upper limit of recommended CYA levels and the resulting super high chlorine levels could damage your pool/equipment.
    Quote Originally Posted by jglorioso
    16k gal, 28'x3.5', Vinyl A/G, 1hp Pentair Dynamo 2-speed Pump, Hayward S160T Sand Filter, Intermatic HB800RCL Digital Timer, Intex 8110 SWG, TF-100 Test Kit, SpeedStir Author: Jesse's Graphical Pool Testing Log
    I will hold back on adding anymore shock to the water. I don't think we are going to get the test kit right now though. I will keep monitoring the chlorine until its at a safer level for swimming. I am secretly hoping something happens and we have to drain the pool because it is NOT level! But we will keep it going as long as we can. Thanks so much everyone, I am glad I found this forum!
    Jen G
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Heads up...if that is the inflatable ring version, that pool is only about 1500 gallons so I would use that for your calculations...I used to have one.
    you are right, it's a little less than 1500! Thanks for the heads up.
    Jen G
    FYI-The pool is pretty much uneven, so we decided to empty it and do a better job of leveling the ground this time! The good news is that I can start fresh with chemicals
    Jen G
    I have a question about the first 4 days getting the water ready. Is dichlor the same as the pool shock that costs about $3 each? That is what I have been using for the past few days and haven't put anything else in the pool yet. It says calcium hypochlorite as the ingredient so I was confused by the instructions on this site if I was using the right "schock".
    Also my ph is showing a higher color of pink than the scale goes up to, is that normal when I didn't even add any chemicals to it at all?
    Jen G
    calcium hypochlorite, I didn't see any that said dichlor. is this not going to add cya???
    Jen G
  20. Back To Top    #20
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Sorry I see you used calcium hypochlorite (cal-hypo). It is not the end of the world, but you want dichlor. If you can not find dichlor, you can purchase Cyanuric acid (cya) and use that in combination with the Cal-hypo (cal hypo does add calcium as well) or beach to do your start up. The poolcalculator.com will calculate how much cya you need. CYA is cyanuric acid, also known as stabilizer or conditioner and can be bought at home centers, hardware stores, and oftern walmart.
    As for your ph, if you FC level is above 10 ppm, then your ph measurement is not valid.
