Thread: Anyone have exp with Aquabot Tjet?
    Have 20x40 vinyl. Looking for peoples opinion . I like that fact it has rubber wheels and filters down to 2 microns. Concerned with water propulsion will it have enough power to transition from deep to shallow or go up side walls of deep end.
    16X24 Oval Doughboy
    11,000 Gallons~
    2 HP Pump
    Sand Filter
    Re: Anyone have exp with Aquabot Tjet?
    I have the Aquabot Turbo TR4RC and it does a good job on my 20x40 vinyl liner pool. It doesn't climb the walls very well right now but it came with foam inserts that can be added to make it better at climbing. Problem is I lost them over the winter so no clue how well they actually work. The remote is useless to me as I've never used it. It does get trapped a lot on my main drains (I have two) which is a pain. There are some products you can buy that fix this but haven't done that yet. Takes a good 4 hours to get mostly clean and misses some spots but it's still better than manual process.
    I bought mine from epic pool supply online. Way cheaper than other places I found and they offer same warranty so it's not like they are an unlicesed dealer.
    2012 (late install) 20x40 inground Oasis steel pool with vinyl liner. Pentair DE Filter with Whisper Flow 1HP pump and Pentair 400K BTU heater.
    2016 Marquis Promise Spa (2 pump model)
