Results 1 to 8 of 8
Thread: Can I put my 18' Intex pool on a concrete slab?
    A friend just gave me an 18' by 4' Intex pool. It's the one where you blow up the top ring. It has no support poles. It did not come with a ground cloth. I intend to put the pool on a 25' by 25' concrete pad, as it's the only level surface on my property.
    Two questions:
    Could the weight of the water cause my concrete to crack?
    Should I buy a ground cloth, or can I just put the pool right on the concrete?
    Thanks in advance for your help!
    24' Above Ground Round
    DE Filter
    Pump 1 HP
    Flow Rate 39GPM
    22,542
    Re: Can I put my 18' Intex pool on a concrete slab?
    Welcome to TFP.
    1) Yes, but not likely.
    2) If it's clean and smooth I'd just put it right on the concrete.
    Samantha Sabrina's Avatar
    Apr 2012
    Bloomsdale, Mo
    346
    It could crack, mostly depends on the thickness of the concrete, rebar, ect.
    Maybe put some foam down first, it would prevent the concrete from possible causing a leak from scrubbing action as you enjoy it and would give a softer surface to walk on.
    Samantha
    In the process of building for a 22' Intex Ultra Frame, (completion date up in the air at this point).
    We could not beat our backyard into submission so we "Buried It".
    Jun 2007
    New Jersey
    653
    I put one of those on an asphalt driveway (pretty rough gravel mix.) The bottom of those things have Kevlar in them, I think, and are very tough. I did use the included ground cloth the first year, but not the second. I never had any problems with the bottom. The donut, on the other hand, was a constant battle to keep it airtight. Happily, I was able to trade up after two years.
    Current: 28,000G 18'x36' I/G AnthonySylvan Plaster; Waterway 60 sq.ft. DE Filter; 1.0hp x 1.65 SF Two-Speed (B2982) WhisperFlo; 2004-Present
    Previous: 40,000G 20'x40' I/G Koven unlined WWII salvage 5/8" marine steel; Lomart Stainless Sand Filter; 3/4hp Hayward SuperPump; 1946-2003 (managed by me from about 1964)
    Ancient Taylor K-2000, upgraded with Taylor CH, TA, and FAS-DPD, and TFT CYA tests.
    Thanks for the responses! I'll give it a go on the concrete.
    DE Filter
    Pump 1 HP
    Flow Rate 39GPM
    mcoonan's Avatar
    Aug 2008
    Mendota Heights, MN
    292
    Go for the foam, it will feel a lot better on your feet. Someone just posted about using the 1/4" fanfold and that it worked great
    Intex Ultra 18' x 52" AG 6,981 Gal.
    3 - 2'x20' solar panels
    Hayward XStream 1500 Cart Filter
    Hayward 1-1/2 HP 2-speed Superpump
    Aquabot Pool Rover
    2-Softub 300 hot tubs (yup just got one for the lake)
    TF Test Kit Doing the BBB for 7 years
    Medota Heights,Minnesota
    Jul 2014
    Tyler/tx
    2
    Was wondering if you did end up setting your pool on concrete and if so, how did it work for you and how did you do it, with or without some kind of cushion, like sand or foam? Thank you for any help on this
    Jun 2015
    Sycamore/Illinois
    1
    Yes - I would like to know how it worked out, too.
    We are looking at buying the same size one but we only have grass in our backyard.
    My husband wants to have concrete poured, but I don't think we need to.
