Results 1 to 7 of 7
Thread: what exactly is this and what would it do
    Alberta, Canada
    177
    I have someone out here (not even a pool store but someone who is in love with their pool store) who just goes on and on about this stuff Ahh-SomeŽ Water Clarifier & Bio-Cleaner.
    I got the company to send me the MSDS sheet just out of curiosity but not being up on the chemisty part I'm wondering what exactly is in it and what it does. I'll attach the MSDS.
    Thanks
    Attached Files Attached Files
    Deena
    http://www.lindbrookstargazer.ca
    100,000 liter IG vinyl liner
    Rolachem Chlorine & Muratic acid Auto feeders/Pool Perfect Auto feeder
    Pentair 30" filter (Tagelus) Sand filter/Centruion switchless pump 1.5/.25 HP
    steinholder's Avatar
    Mar 2012
    Wichita, KS
    81
    Re: what exactly is this and what would it do
    I just googled the ingredients, it looks like it is a water softener and an algaecide.
    22'x52" AG Ultra Frame Intex - 12,500 gal (47K liter)
    Manual Liquid Chlorine - 1HP 100# Hayward sand filter
    Lots of sun, trees, pollen & wind - 50ppm Borates
    4nd season grateful TFP fan
    Alberta, Canada
    177
    Quote Originally Posted by steinholder
    Ahh, yes, I never thought to do that. Thanks.
    Deena
    Mar 2007
    San Rafael, CA USA
    12,082
    The "Sodium Sesquicarbonate" is the same as a combination of sodium carbonate (i.e. "pH Up") and sodium bicarbonate (i.e. "Alkalinity Up) so would raise both pH and TA. The "Alkyl Dimethyl Benzyl Ammonium Chloride (C12-18)" is what is known as a linear quat algaecide which is a less expensive algaecide compared to Polyquat but can foam. I didn't see any clarifier in the ingredients.
    The guy probably goes on and on about this product due to the algaecide because he is likely using Trichlor pucks/tabs where the CYA buildup leads to algae growth if one doesn't use an algaecide product. Also, Trichlor lowers the pH and TA to this product seems like a miracle since it restores both (somewhat).
    Alberta, Canada
    177
    Quote Originally Posted by chem geek
    Thanks "chem geek". He does indeed use Trichlor pucks and has had algae growth. So I guess it is a miracle for him. An expensive miracle though, he goes through a ton of it.
    Deena
    Mar 2007
    San Rafael, CA USA
    12,082
    Yeah, linear quats break down from chlorine quickly. He would be much better off using Polyquat even though it is more expensive (though perhaps not more than what he is using now) since it will last longer so use less chlorine. Of course, it would be even better if he went the BBB route, but Trichlor pucks are convenient. Some people are willing to pay more for such convenience even though it means paying extra for algaecides or phosphate removers.
    Alberta, Canada
    177
    I hear you on all of this....one of his biggest problems is he is also a male chauvanist. He thinks because I am female, my poor little girl brain could not possibly know anything.
    He was a little blown away this past weekend when thanks to people here, I took apart my pool pump and replaced the motor shaft seal. Now he thinks maybe my little girl brain can actually hold something so maybe I will convert him to BBB yet....lol.
    I have printed off this thread for him to read.....his comment....a great big...hmmmmmm.
    Deena
