Results 1 to 7 of 7
Thread: Hayward H400 Heater HELP!!
    May 2012
    Oceanside, CA
    4
    I have an older model of the H400, recently when the heater attempts to light, it seems to 'blow' itself out. That is that if I put my hand over the exhaust, I feel heat, then a pulse of the blower, then no heat. The system resets. If I were partially obstruct the exhaust during the lighting process, then the heater will remain lite and function properly. Any ideas out there; thanks in advance!
    Stan
    ps0303's Avatar
    Jul 2011
    FL
    3,695
    Re: Hayward H400 Heater HELP!!
    If you have a "blower" in your Hayward heater, then it is a Universal H-Series heater, yes? The older H-Series model do not have a blower motor. Please let us know the exact model you have to effectively help you.
    Paul
    http://www.gastekservice.com A word of caution: When working with gas and electrical you might want to consider a licensed contractor. Consider the value of your life and others around you. If you would like to provide a review of the help I provided, please use the following link to leave a review. gastek - Google Search,
    May 2012
    Oceanside, CA
    4
    The model is H400IDL, I hope this helps!
    Jun 2010
    Dripping Springs, TX
    125
    Hi rabys,
    I don't know if this is your issue or not, and I'll certainly defer to ps0303 and his recommendation, however I have a similar heater and had many issues with it when I first got it.
    I friend of mine looked at it and made a fix to it - it has worked like a charm ever since.
    I posted what he did here:
    solution-for-hard-to-fire-hayward-heater-t27462.html
    If you think this is your issue and you need any help, I'm happy to explain.
    SF
    17K gallon IG freeform Pebble-Tec pool w/ raised spa/waterfall, Hayward 6020 DE filter, Tristar 1 HP circulation pump, Tristar 2.5 HP spa pump, Silencer 2hp blower, Aquarite SWG, Polaris 280 w/ booster pump, Hayward Universal H-Series 400K LPG heater, Ultrapure Ozonator 25, Aqualogic PS-8
    May 2012
    Oceanside, CA
    4
    Yes, I read through this solution of yours before posting my question. Seems to be a logical solution, though I was hestitate to try it without further input. The heater has worked fine since it was new, this problem is occurring more and more frequent with time. I'll review your suggestion and ask questions if necessary. I'm trying to find the "heating element" on the parts list and cannot find it, to get an idea of what you are referring to. Are your referring to the 'ignitor'? Thanks, I appreciate the feedback!
    Jun 2010
    125
    Yes - by heating element I mean igniter. It is a pencil shaped part that is mostly covered by a white ceramic material, with bare metal protruding from one end.
    May 2012
    Oceanside, CA
    4
    OK, I actually had to replace this part due to my clumsiness, very brittle and I broke the element. However, the ignitor on this particular model was only the serpentine element connected to the ceramic piece, which slipped into the burner chamber and secured with two screws, see attached. There was no metal 'guard' surrounding the element itself.
