Thread: Estimating how many gallons of water
    lulupalooza's Avatar
    Mar 2008
    Evans, GA
    ok I just used the pool calc. and if I did this right then the est gallons for a 24x52 is 14700 gallons??? is this correct
    *~ Laura ~*
    27x52 Aquasphere Conquest AGP (approx.17,100 gal)
    1 HP Pentair Dynamo Pump & SD-40 Sand Filter
    TF-100 Test Kit
    BBB User- Salt Added
    Mar 2007
    Coastalish 'down easter'
    Laura, the 52" is the hight of the walls, the water depth is probably closer to 48" - therefore your gallonage is closer to 13,000 - 14,000 (my calculations say "13,593.6")
    Luv& Luk
