Results 1 to 11 of 11
Thread: Greetings, Heat pump heating pool more slowly.....
    Living in Stirling, Ontario where I installed an in ground, 19' by 36' kidney shaped, Did all the work myself and saved a great deal of money although it was more work than I planned on. Hayward pump and filter with Titan 2 heat pump.
    Seems to me that the heat pump is heating the pool more slowly every year. Got it up and running three days ago and the initial temperature was 50C this morning it's 73C....... so it is working however sloooooowly.
    Also the flo switch seems to have packed it in. Couldn't get the flo switch to let the pump turn on no matter where I set the calibration. So I made a jumper and shorted the two wires leaving the switch and that got it running.
    I'll have to get a pro in to service this thing but I'm wondering if anyone has similar experiences with heat pumps
    Chris
    Pool: Intex Ultra 16' x 48"(5061g) with Hydrotools wide skimmer, on 1" xps setup on 6/2/12
    Pump: Intex 2650
    Filter: Intex 2650 Sand filter
    Heater: Hayward H100ID1
    SWG: Intex CS8110
    30,427
    Re: Greetings Fellow Pool People
    Cant answer your question but welcome to the forum.
    elwood58's Avatar
    May 2012
    Sun City West Arizona (2nd Home)
    654
    I assume you actually meant F on your temperatures. If your pool is at 73C, then it is now a very hot place to swim, as in burn your skin.
    19204 Gallon L Shape with a 10X10 2nd Step Baja Ledge. Intellichlor IC-40, IntellipH, Cartridge Filter, Pentair Heater/Chiller (Heat Pump). Tons of Deck with Deck Jets. Construction Complete 6/5/17.
    "If you don't measure it, you can't manage it!"
    Quote Originally Posted by elwood58
    Yes I meant F ( it was fairly early when I posted and I wasn't fully awake I suppose) so...... well spotted indeed.
    Do you have any input wrt my heat pump issues or are you just the proof reader on this board?
    Chris
    Pump: Intex 2650
    SWG: Intex CS8110
    Butterfly's Avatar
    South Carolina
    10,045
    Welcome to the forum
    I'm moving your post over to the equipment forum to see if you can get some answers about your heater.
    You're done SLAMing when:
    GreatCanadian's Avatar
    Jul 2011
    St. John's, Newfoundland
    844
    Re: Greetings, Heat pump heating pool more slowly.....
    Quote Originally Posted by Klimbimm
    ...Do you have any input wrt my heat pump issues or are you just the proof reader on this board?
    Well. He sounds like a jolly young fellow now doesn't he!
    13'x22'x52" 8,000 gallon ProSeries Pool with Borates
    Intex 110 pound Sand Filter with Zeobrite, 2650 gph pump, 0.95 hp
    Bestway SWG
    AquaPro ECO500 50,000 BTU heat pump
    GLI Whirlwind Solar Cover Reel, TF-100 Test Kit
    Jun 2012
    western NY
    1,561
    Does this heat pump work off of a ground loop or does it use the ambient air around it? Also, how many gallons of water and what BTU output is the heater (different from input). If the pump uses ambient air for transfer, what has the air temps been at night and durring the day? Do you have a solar cover on the pool?
    Unknown make 18' above ground (bought used in 1999) Sparco sand filter. Hayward 100,000 BTu heater. 2 speed pump
    Greetings, Pump uses ambient air. It was quite cool in the evenings getting down to 10 at times. It just seems to me that year after year the heater works a little slower. I'm going to take the screen off and use a brush on the radiator........ give it a good cleaning. Perhaps that will improve the performance.
    Incidentally I bought a new flo switch ($35) and replaced the one I suspected was u/s. Working fine now. The flo switches just unscrew, no tools required.Very esy to replace without calling a service guy. Yay!
    Chris
    Pump: Intex 2650
    SWG: Intex CS8110
    Quote Originally Posted by GreatCanadian
    Yeah, well...... pet peeve of mine............. if it was so obvious why bother to point it out?
    Chris
    Pump: Intex 2650
    SWG: Intex CS8110
    harleysilo's Avatar
    Mar 2012
    North Georgia
    1,924
    Have you tested the temperature of the water being returned into the pool, compared that to the pool temp to see if it's heating up to its rated capacity?
    18'x43' Sport Pool
    19,000 Gallons Vinyl Liner 3'-3.5'-4'
    SWCG and D.E. Filter
    Test Kits - Pool Calculator - Chlorine/CYA Chart - Pool School
    Secret Weapon for Pool Chemistry Testing
    Quote Originally Posted by harleysilo
    that's a good idea. I will do that
    Chris
    Pump: Intex 2650
    SWG: Intex CS8110
