Thread: Pool railing hole covers
    I have a pool railing that is not being installed on my concrete deck this year. Does anyone make covers for the holes/recepticles for the railing? I'd prefer cromed plastic or stainless but anything is better than a big empty hole.
    Scott
    Melt In The Sun's Avatar
    Oct 2009
    3,899
    Re: Pool railing hole covers
    Are the holes threaded or smooth? I bet it wouldn't be too hard to find some kind of plug to fit nicely in there, in a variety of materials.
    Apr 2011
    Lynchburg VA
    393
    PVC caps come to mind as something that would fill these holes nicely!
    18x36 Vinyl In-ground w/roman ends 27,400G, Hayward 3/4hp with 300# sand filter. Hayward heat pump heater
    Pool School
    Pool Calculator
    Test Kits
    Jul 2009
    Olney, MD
    218
    I use 2" test plugs to keep water out of mine in the winter.
    20k gal, IG Vinyl, IntelliFlo VF Pump, 60 GPM sand filter, Jandy Aquapure Ei 35, 2 skimmers, one main drain, two returns, Dolphin Diagnostic cleaning robot, Taylor K-2006 test kit
