Thread: Smartphone on-line pool test
    Hmmmm.... This looks interesting. Apparently you dip the strip and lay it next to a calibrated "master" and photograph it with your smartphone. The photo is then analyzed by some software and your pool test is then displayed. http://insta-link.com/
    Pool: IG 22k- 16x32 clipped corners- vinyl liner, w/ a great board. Built in 3/99, new to me 2/2011.
    Equip: Hayward 3600 DE filter, Hayward CL-200 Chlorinator (empty since 7/5/2013).
    K-2006 Test kit with Speedstir
    Located in Cincinnati, OH. TFP lurker since 9/2011, BBB interested since 5/2012 and converted 7/2013.
    Re: Smartphone on-line pool test
    Unfortunately, no matter how good the scanning software in the smart phone, you are still limited by the imprecision and generally low reliability of test strips.
    Ya that was kinda my thought too.
    Jul 2012
    Basking Ridge, NJ
    46
    I've been using this for about a month now and I have to say that I really am impressed with the results. I did an analysis with the phone app and reference card and then immediatly took a water sample to my local pool supply (they have a battery of tests and brand new digital equipment, quite impressive I must say) and the difference in the numbers upon comparison was almost negligable. My only real problem with it is that the app is somewhat sluggish so you have to navigate to the photo scan page and then dip the strip and scan. A little annoying at first, but once you get it down it's not that much of a hassle.
    28,000 Gal Pool w/ Attached raised Spa, White Plaster Finish, D.E. Filter - FNSP 60 sq. ft., Whisperflo Pump, Nature 2 Element (Housing Only Now Devoid of Cart.), Hayward CL200 In-Line Automatic Pool Chemical Feeder, RayPak Gas-fired Heater, Polaris 380, Zodiac 1.5-HP 240-Volt Polaris QT Spa Blower
    30,431
    DISCLAIMER...I sell a drops based test kit.
    That said, taking a test strip phone analysis to a pool store with test strip digital testing is reminiscent of the blind leading the blind. Neither approach is accurate and usually not even repeatable so there is no reason to ever compare the two.
    The digital printouts all look quite impressive down to the hundredths of a ppm (wow, really?) when in actually they can be completely worthless in many if not most cases.
    If the technology has test strips in it, it simply cannot be relied upon to successfully manage your pool....regardless of how "slick" the results may appear.
    What would be an accurate comparison is a test with your phone app and then an immediate test with Taylor reagents from the same bottle of pool water. Just saying.. .
