Thread: Hayward Superpump Question.
    mcoonan's Avatar
    Aug 2008
    Mendota Heights, MN
    292
    I have a Hayward Superpump with 1 1/2HP 2-speed General Electric Pool Pump Motor on it. The label on it is mostly unreadable. I can get some numbers off of it:
    HP 1 1/2
    V 230
    PH 1
    RPM 3450/1225 ??
    Swim Pool Motor
    A 6.9/2.6
    Cat# C1112
    Cannot read the wiring diag.
    The way I read it, it is a 230 volt only (no 115) motor. 6.9 amp on hi-speed and 2.6 on low speed.
    Sound correct? Anybody with the same motor?
    Tried GE and Marathon a few weeks ago and never got a reply.
    Thanks
    Mike
    Intex Ultra 18' x 52" AG 6,981 Gal.
    3 - 2'x20' solar panels
    Hayward XStream 1500 Cart Filter
    Hayward 1-1/2 HP 2-speed Superpump
    Aquabot Pool Rover
    2-Softub 300 hot tubs (yup just got one for the lake)
    TF Test Kit Doing the BBB for 7 years
    Medota Heights,Minnesota
    Re: Hayward Superpump Question.
    What are you trying to figure out?
    The low speed RPM is 1725.
    mcoonan's Avatar
    Aug 2008
    Mendota Heights, MN
    292
    I thought that the 1225 sounded strange.
    That it only a 230 volt motor and the amp is 6.9/2.6 at 230 volt.
    With how unreadable the label is, I am guessing at those numbers.
    Used a magnifying glass to get as far as I did.
    I did plug it in to 115 and it ran kind of.
    Ran much better on 230 and hi and low works.
    Now it has new seals and gaskets and ready to be wired in and plumbed!
    Aquabot Pool Rover
    mcoonan's Avatar
    Aug 2008
    Mendota Heights, MN
    292
    Just thought of something as I was pondering the wiring.
    Any thoughts on a timer? Would I need a timer for 2-speed or just a standard timer?
    Any recommendations?
    Aquabot Pool Rover
    22,553
    That's strictly a 230 volt motor.
    A two speed timer works better but you can use a single speed one and just manually switch between low and high.
    Those amp numbers are reasonable. It looks like it has an up rated standard efficiency motor.
