Thread: Raising TA w/o raising PH?
    Mar 2011
    Sunny Central Florida
    91
    So yesterday I did my monthly full test:
    PH 8.0
    FC: 5
    TC: 5
    CC: 0
    CYA: 30
    TA: 70
    CH: 200
    I added a couple of cups (2 or 3, I didn't measure, just glugged it out of the bottle) of muriatic acid. Tested again today and got:
    PH: 7.4
    TA: 30
    So, now I need to raise my TA, right? Isn't baking soda going to just raise my PH too, then I'll add acid to lower PH and destroy my TA and end up in the same spot? I have soda ash too, if that is better.....Help!!
    IG Plaster 20,000gal, attached spa w/ spillover, hayward C12002 cart filter, 1 1/2hp pump w/ polaris 360
    6/16/12 - PH 7.6, FC 6, CC 0, CYA 30, TA 80, Calcium 310
    Butterfly's Avatar
    South Carolina
    10,045
    Re: Raising TA w/o raising PH?
    First, retest TA wiping the dropper between drops. If still low, then:
    Use baking soda and get your TA up to recommended levels. It will raise pH, but only slightly. You can use MA to lower the pH again - if needed.
    Use the PoolCalculator.com to determine doses.
    You're done SLAMing when:
    Feb 2012
    Stowe, VT
    59
    What are you using to chlorinate your water? I use to worry about "lower range" alk but found that it would always sit there no matter what, I compensated by increasing my calcium hardness a bit to keep CSI near 0. Don't forget to use the pool calculator to get accurate dosage, and also make sure to measure the amounts you put in rather than guessing so you don't need to add addition chemicals. Good luck.
    69,000 Gal gunite indoor IG pool.
    5 HP Emerson - Pentair Triton II Commercial TR140c Sand Filter x2
    5,000 Gal gunite outdoor IG hot tub
    2 HP Sta-Rite - Pentair Triton II Commercial TR140c Sand Filter
    30,431
    You won't need to wipe the dropper tip. That tip is for a VERY new kit and when the TA measures UNUSUALLY high. Yours is, of course, too low.
    As BF says, Baking soda will bring your TA up where it belongs and I doubt you will even be able to measure the SLIGHT change in pH.
    Mar 2011
    91
    OK, I'm a dope, LOL. As I was re-doing the TA test, I realized when I got that 30 reading, I'd only filled the tube up to 10ml, like I was doing a CL test. It's fine....back to 70. I'm so glad I didn't dump a bunch of stuff in the pool before posting Thanks butterfly!!!
    Butterfly's Avatar
    South Carolina
    10,045
    Quote Originally Posted by danivdp
    Don't ask me why I KNOW you should always step back and retest FIRST
    You are NOT the only one to make that little mistake
