Thread: New pool owner
    May 2012
    Elgin/Ft Sill, OK
    2
    New pool owner
    Just purchased a house with an IG vinyl pool. Getting a handle on water chemistry with BBB program but not sure how to do filter maintenance. When we moved in a week ago the filter system was running 22 psi but today it was at 29 psi. I think this indicates a need to backflush the sand filter but not real comfortable doing this the first time. Also not sure when the filter medium was last changed, I know the pool was left open this past winter. I am more of a visual learner and although I have read the procedure for backflushing just nervous about not setting something correctly and messing up majorily. Thanks for any help. Steve.
    16 x 32 vinyl IG pool approx. 24,000 gallons (8.5ft diving deep end & 4ft deep shallow end)
    1HP pump with flow rate of approx. 82 GPM; Hayward Pro Series High Rate Sand Filter and Hayward H250 series heater
    TF100 Test kit
    Hot Springs Portable Spa
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,655
    Re: New pool owner
    pool-school/cleaning%20pool%20filters
    Straight outta pool school for ya'!
    Butterfly's Avatar
    South Carolina
    10,045
    Re: New pool owner
    Hi Steve and welcome to the forum
    Do you have the manual for the filter?
    The most important thing, IMHO, is to ALWAYS turn the pump OFF before you move the filter valve.
    Example:
    First, I always drop a hose in the pool and start adding water because backwashing removes water from the pool.
    Turn off pump and move spider valve to 'Backwash'. Turn pump ON.
    After water in site glass runs clear, (usually 3 or 4 minutes) turn pump OFF.
    Move spider valve to 'Rinse'. Turn pump ON.
    Run for about 30 seconds and turn pump OFF.
    Move spider valve to 'Filter'. Turn pump ON.
    Done. Notice your psi reading. This is your 'clean filter psi'. Once the psi rises about 25% over the clean psi, time to clean filter again.
    Now you prob need to add some more water to the pool.
    Wait, I might have missed something. Read this first! Here's the article Waste wrote in Pool School: pool-school/cleaning%20pool%20filters
    You're done SLAMing when:
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,073
    Re: New pool owner
    There are videos on youtube showing backflushing. Watch a few.
    May 2012
    Elgin/Ft Sill, OK
    2
    Re: New pool owner
    OK. Got all the numbers right I think except for TA. Everything I read says to lower my pH to 7.0-7.2 and then aerate to rasise pH back to desired level. Not sure how to accomplish the aeration process so any input would be helpful.
    Would building an attachment that goes on the return line and then elevates out of the water like a sprinkler work?
    Here are the numbers for the pool; these came from the local pool store and jibed pretty closely to my first try with the TF-100.
    FC: 3
    TAC: 3
    pH: 7.6
    TA: 120
    CYA: 40
    CH: 225
    TDS: 450
    Thanks for all the help. Really liking the site.
    Steve
    TF100 Test kit
    Richard320's Avatar
    Jan 2010
    19,073
    Re: New pool owner
    Quote Originally Posted by oatmans
    Yes. There are links to some threads that have pictures of just such things in this article: pool-school/lowering%20total%20alkalinity
