Thread: Trouble with Minimax NT
    First of all Hello to!
    I have a minimax nt that is about 6-7 years old. I have recently started noticing that the heater will show a hotter temp on the display (about 25* higher than water temp) and it will not let the water get any hotter. If I raise the temp on the heater itself, say to the max of 104* it will heat till it believes it is at that temp. For instance again today, the water temp is 77* and when I looked at the heater it said 100*. No error codes given and appears to be functioning fine. Is there a calibration that I'm missing or has something let go?
    Thanks in advance,
    Nate
    ps0303's Avatar
    Jul 2011
    FL
    3,682
    Re: Trouble with Minimax NT
    No there is not a calibration. Sounds like the temp control board is going bad.
    Paul
    http://www.gastekservice.com A word of caution: When working with gas and electrical you might want to consider a licensed contractor. Consider the value of your life and others around you. If you would like to provide a review of the help I provided, please use the following link to leave a review. gastek - Google Search,
