Thread: Robotic Clean in High Chlorine
    Mar 2008
    Pelham Alabama (Birmingham)
    69
    Quick question.
    Any concerns with using a robotic cleaner (Aquabot T2) in the pool while the pool is being shocked? I'm thinking no, just being sure. I had a Polaris 280 (great unit) in the past that had internal drive belts that would tend to deteriorate, I believe due to use in high chlorination. Any high chlorine issues with the Aquabot?
    Thanks
    IG 18 x 36 Vinyl
    30,000 Gallons
    AutoPilot SWG
    Aquabot T2
    Hayward S244 Sand Filter
    Hayward 1hp RS1000 Pump
    Leisure Bay Spa - Flores - 500 Gallons
    AutoPilot SpaPilot - Not Yet Installed
    If you are using CYA in an outdoor pool and are only shocking up to normal shock levels then I wouldn't worry about it at all, everything should be fine. Indoor pools without CYA are much more likely to cause problems.
    I have the Auquabot. It is entering its 8th season. I routinely add chlorine in the evening at the same time as the robot. As I have gotten better with maintaining my pool, the need for "shocking" has decreased. I managed most of last season without super-chlorinating...no CC during testing.
    That being said, in previous seasons, I would "shock" and toss the robot in at that the same time. No real problms. You will be doing some repairs to the robots over the seasons...mine is getting all new bands, brushes and tracks this season...from aquabots.com...nice site.
    25,000 gal IG Utopia pool/Raypack gas heater/BBB
    Mar 2008
    69
    Thank Fellas,
    I appreciate it. In the past I've used the Polaris 280 (nice unit), and a Hayward Phantom (hated it since taking it out of the box), neither of which even comes close to my new AquaBot T2. At least not in the week or so of it's use.
    IG 18 x 36 Vinyl
    30,000 Gallons
    AutoPilot SWG
    Aquabot T2
