Results 1 to 15 of 15
Thread: Fine tuning my water balance suggestions
    Mar 2012
    Eastern Long Island,New York
    82
    28000 swg VINYL inground pool with the following:
    ph 7.0
    FC 4.6
    TA 103
    CH 124
    CYA 36 But added almost 6 lbs less than 24 hours ago
    salt 3400
    borate 33
    csi -0.9
    Do I just aerate to raise pH or add some baking soda? If so how many days of aeration as i won't be home till next Friday. I can leave on the stairs jets, glorified bubble maker.
    Pool only open 1 week
    Thanks for all the help and suggestions.
    Rich
    20 X 40 Vinyl IG 28K gallons, Heat Siphon Z700HP, Hayward 4820 DE, Hayward SP3400VSP, Jandy aquapure 1400, TFTest Kit, Pool School, Pool Calculator
    Butterfly's Avatar
    South Carolina
    10,045
    Re: Fine tuning my water balance suggestions
    We use Borax to raise pH and use Baking Soda to raise TA.
    So, I suggest you use borax and raise the pH to about 7.4.
    What is CC test result?
    You're done SLAMing when:
    What kind of pool do you have (vinyl, fiberglass, plaster, pebble, etc)?
    Mar 2012
    82
    Thanks
    Its a vinyl pool..
    Mar 2012
    82
    P.s.
    Whats the difference between By weight or By volume?
    If I buy a box of borax what does the box correspond to?
    Thanks again
    30,426
    weight
    "by weight" means weighing on a scale. "by volume" means measuring in a measuring cup. Most solids are sold be weight. Most liquids are sold by volume.
    Mar 2012
    82
    5 days later:
    PH 7.8
    FC 3.5 ppm
    CC 0.5
    TA 140
    Ch 220
    CYA 70
    Borates 30-35 ppm
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Are you having problems with ph rise? If you are, then lowering TA makes sense. You can use the "effects of adding chemicals" section near the bottom of the poolcalculator.com to see approximately how much your TA will move down when you add MA. How long just depends on how much aeration you get and it is a slower process as your TA gets lower. Have you read: http://www.troublefreepool.com/pool-...l%20alkalinity
    Mar 2012
    82
    Yes I did read it.
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    One nice thing about TA, it typically lowers itself overtime, since higher TA causes ph rise and then lowering ph with acid also lowers TA. The net effect is a slow lowering of TA unless you are constantly filling your pool (i.e. lots of evaporation, splash out, etc.) with high TA water .
    Mar 2012
    82
    Just retested with the following results:
    PH 7.8
    FC 4.0 ppm
    CC 0
    TA 130
    Ch 220
    CYA 70
    Apr 2012
    Lake Charles, Louisiana
    31
    No expert here, but yes you should use MA to lower you pH. 7.5 if you're not trying to lower TA any further and 7.2 if you are. Someone please correct if I'm wrong.
    ~20,500G 18x36 IG Vinyl Sports bottom
    300lb Hayward sand filter 1HP Hayward superpump
    Aquarite SWG T15
    Mar 2012
    82
    Thats exactly what i put in the pool calculator.
    Yes, swimming is fine down to a PH of 7.2.
