Thread: Filter loses water to waste?
    Jul 2009
    Massachusetts
    188
    I have a multi-port valve and I just started running the pump and I noticed that when the valve is set to recirculate and/or filter, i lose water through the waste line.. last year, we replaced the valve after the stem broke and it worked for the season, no strange water loss at all.. and it's unlikely the pool closers unscrewed all 8 screws to open up and mess with the valve, right? what am i missing here? btw, it's not a slow drip either (there's a spout next to the waste line, and it's a pretty significant flow of water).
    also, i haven't added any DE to the filter yet - i was just planning to recirculate the water before i did my first TF100 test for the season and noticed i was losing water to waste.
    thanks, patty
    25,000 gallon gunite pool with waterfall (built 2000 - owner as of 2009), Aerotemp / Aquacal heat pump AT12000-A, Hayward DE4800 Filter, AOS UST1202 Motor, Hydro-King T104P201 Timer, Meyco pool cover, Pentair Model 320 Auto Chlorine Feeder. Located in Massachusetts.
    Jun 2007
    New Jersey
    653
    Re: Filter loses water to waste?
    Odds are your spider gasket has come loose. I had this fail on a brand new valve after a short period of time because the factory forgot to use any glue. Waterway sent me a new spider gasket (it became cut where the rotating component pressed down on it) and told me to SuperGlue it.
    I think you have to open the valve to see what's going on.
    Current: 28,000G 18'x36' I/G AnthonySylvan Plaster; Waterway 60 sq.ft. DE Filter; 1.0hp x 1.65 SF Two-Speed (B2982) WhisperFlo; 2004-Present
    Previous: 40,000G 20'x40' I/G Koven unlined WWII salvage 5/8" marine steel; Lomart Stainless Sand Filter; 3/4hp Hayward SuperPump; 1946-2003 (managed by me from about 1964)
    Ancient Taylor K-2000, upgraded with Taylor CH, TA, and FAS-DPD, and TFT CYA tests.
    Jul 2009
    Massachusetts
    188
    alright, thanks durk.. hope you are enjoying the weather in NJ this weekend as much as we are in MA.
