Results 1 to 14 of 14
Thread: new t-15 cell won't recalibrate
  1. Back To Top    #1
    Join Date
    Jul 2011
    Location
    Greenwood, Indiana
    Posts
    42
    I keep getting Hi salt readings on my SWG so it's not producing any chlorine. We've drained almost 1/3 or the pool, refilled and tried still no luck. SWG says salt is 4200. Strips and pool store say around 3200. I tried the steps to recalibrate but after I push the diagnostic button 5 times and the negative number starts to go down it stops and then quickly drops to zero because the high salt light comes on. Is there a trick to get it to recalibrate? We had a T-5 cell but when we replaced were told we needed to use the T-15. It's brand new put it in last week and hasn't worked properly since. Any suggestions?
    Thanks!
    18,000 gallon in ground SWG sand filter electric cover
  2. Back To Top    #2
    JasonLion's Avatar
    Join Date
    May 2007
    Location
    Silver Spring, MD
    Posts
    37,879
    Re: new t-15 cell won't recalibrate
    The chances are excellent that your salt level really is too high and you simply need to replace more water. It is very common for the old cell to read a lower than actual salt level for some time before it fails completely, leading you to add too much salt. When you get a new cell it reads the salt level correctly and suddenly shows the high salt level. The only alternative at that point is to replace water to get the salt level down.
    It is very common for salt test results to be significantly wrong. The goal here isn't to hit some specific absolute salt level, the real goal is to keep the SWG happy. It wants less salt, so that is what you need to give it.
    19K gal, vinyl, 1/2 HP WhisperFlo pump, 200 sqft cartridge filter, AutoPilot Digital SWG, Dolphin Dynamic cleaning robot
    Creator of PoolMath and Pool Calculator. Other handy links: Support this site, TF Test Kits, Pool School
  3. Back To Top    #3
    Join Date
    Aug 2011
    Location
    Metro Atlanta, Georgia
    Posts
    161
    Did you change the setting from T5 to T15 ?
    My cement pond is a 36K gunite 20X40 built in mid 1960s, Hayward S244S filter, Aquarite SWCG, Jandy 1.5HP 2sp, TF-Test kit and Nitro Wall Climber
  4. Back To Top    #4
    Join Date
    Jul 2011
    Location
    Greenwood, Indiana
    Posts
    42
    We were told we didn't need to change any settings....and I don't know where or how to do that...
  5. Back To Top    #5
    5. "High Salt" LED illuminated
    Be sure that the correct model Turbo Cell has been selected (page 7).
    To Set Turbo Cell Type
    Before operation, the Aqua Rite must be configured for the chlorinator cell that will be used. Refer to the following information and steps below to set the Turbo cell type.
    "t-3" = T-CELL-3, GLX-CELL-3-W
    "t-5" = GLX-CELL-5, GLX-CELL-5-W
    "t-9 = T-CELL-9, GLX-CELL-9-W
    "t-15" = T-CELL-15, GLX-CELL-15-W
    1. Slide the Main Switch to the "Auto" position.
    2. Push the Diagnostic button repeatedly until "t-xx" appears on the display ("t-15" is the factory default). If the desired cell type is displayed skip to step 4.
    3. To change to a different cell type, slide the Main Switch from "Auto" to "Super Chlorinate" and back to "Auto". Repeat this process until the desired cell type is displayed.
    4. Push the Diagnostic button to exit.
    http://www.hayward-pool.com/pdf/manuals/Manual345.pdf
  6. Back To Top    #6
    Join Date
    Jul 2011
    Location
    Greenwood, Indiana
    Posts
    42
    I never get a "t" reading of any sort no matter how many times I push the diagnositic button and no matter which setting it is on.
  7. Back To Top    #7
    Join Date
    Jul 2011
    Location
    Greenwood, Indiana
    Posts
    42
    and it clearly says T-5 on the board....but we were told they no longer make T-5 and we need T-15....
  8. Back To Top    #8
    dremin2flyhi's Avatar
    Join Date
    Jun 2010
    Location
    Darlington, SC
    Posts
    121
    they still make the T5 or GLX-CELL-5-W --it is the same one used for the Aquatrol units... Do some searching on google --they have them all over.
    What software version is the Aqua rite unit-- I know some of the older versions of firmware--you could not change the Cell type.
    24' x52" Sharkline Venture (May 2016) ABG (13,500)
    Hayward S180T15932S --Sand filter/ Flo-Matrix pump pack
    Aquatrol-RJ SWG-- Nitelighter NLMC
    Dolphin E10
    Duraspa G2- Premium hot tub --Rotomold style
  9. Back To Top    #9
    Join Date
    Jul 2011
    Location
    Greenwood, Indiana
    Posts
    42
    I'm not sure which software version it is....how do I find that out? (We did not install this.....it was here when we bought the home).
  10. Back To Top    #10
    Join Date
    Jul 2011
    Location
    Greenwood, Indiana
    Posts
    42
    I think the guy who works on my pool is smoking crack.....and we just need to buy a T-5 and not a T-15.....
  11. Back To Top    #11
    Join Date
    Jun 2010
    Location
    Darlington, SC
    Posts
    121
    cycle the diagnostics button--you will see r-?.?? that is the version number .. If you have the 1.40 you maybe stuck with the T 5 like me
    Dolphin E10
  12. Back To Top    #12
    Join Date
    Jul 2011
    Location
    Greenwood, Indiana
    Posts
    42
    yep 1.40....
  13. Back To Top    #13
    You might want to contact Hayward to see if they can help.
    http://www.haywardnet.com/forms/contactForm.cfm
  14. Back To Top    #14
    Join Date
    Jul 2011
    Location
    Greenwood, Indiana
    Posts
    42
    just ordered a T-5....returning the T-15....crossing my fingers
Posting Permissions
  • You may not post replies
  • You may not edit your posts
