Results 1 to 13 of 13
Thread: What is the most cost effective way to raise CYA?
    Greetings!
    What is the most cost effective way to raise CYA? I've read somewhere to put calcuim chloride in a sock in the skimmer but can't find the article anymore on Google so not 100% that is what it said. Secondly, if this is true, where can buy this at in bulk. My CYA is 15 so need to add alot.
    Second question, is it ok to run SWG with CYA at this level?
    Thank you,
    Mike
    30,414
    Re: What is the most cost effective way to raise CYA?
    Welcome to the forum.
    Simply, the most effective way to buy CYA is to purchase it by itself. Calcium chloride contains no CYA.
    It's fine to run your SWG but you are sucking up a lot of chlorine with your CYA that low. You will have to dial SWG back when you put in CYA.
    There is no commonly available substitute for cyanuric acid. You need to get it from a pool place. That said, there are usually some fairly good deals at Amazon and WalMart.
    Apr 2011
    Lynchburg VA
    393
    Lowe's carries it as well!
    18x36 Vinyl In-ground w/roman ends 27,400G, Hayward 3/4hp with 300# sand filter. Hayward heat pump heater
    Pool School
    Pool Calculator
    Test Kits
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,581
    I, as well as a lot of other folks, have found that the CYA from Walmart seems to dissolve very fast.
    Thanks everyone for posting so far. I read somewhere where the stuff de-icer is made out of is good way to increase your CTA, is this true? If so, where would I find it in bulk?
    Mike
    Jul 2009
    Olney, MD
    218
    Quote Originally Posted by geturdone
    Mike
    You are mixing up CH and CYA, the de-icer will add calcium (CH) to your pool, not CYA (cyanuric acid, which is stabilizer).
    20k gal, IG Vinyl, IntelliFlo VF Pump, 60 GPM sand filter, Jandy Aquapure Ei 35, 2 skimmers, one main drain, two returns, Dolphin Diagnostic cleaning robot, Taylor K-2006 test kit
    Ah, gotcha...I found 3.75 lbs of stabilizer at Lowes for $15 so best price I found so far so got some.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,984
    Good job. As a bonus, you didn't have some ninny trying to sell you some miracle snake oil.
    It is better to go low on the CYA addition. It's easy enough to add more later, no way to easily remove too much besides draining.
    Amazon is about 6% less expensive than the Lowes price you posted if you get 8 lbs.
    Thanks for sharing...it all adds up
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Welcome to tfp, geturdone
    We are always interested in test results if you have some
    chiefwej's Avatar
    Jun 2011
    Tucson
    2,943
    If you don't know the difference between CYA and CH, you need to read and study Pool School.
    chiefwej
