Thread: Please Help me Have stain? pool store got me in this mess
    Have yellow stains on steps and around vinyl liner. pool 18x36 20000 gal. inground. I put vitamin c tablet on step cleared stain off step. What do I need to do now? This is my test results: TDS 400, Total chlorine 8, Free Chlorine 8, PH <6.2, Total alkalinity 10, Adjust alk. 0,Total Hardness 120.
    Help what to do? I'm newbiee just found site so simple terms thanks.
    5061 gallon 16X48 Intex AG
    1000 gph cartridge filter/pump
    vinyl liner
    Butterfly's Avatar
    South Carolina
    10,045
    Re: Please Help me Have stain? pool store got me in this mes
    First, get your pH and TA adjusted to recommended levels ASAP. pool-school/recommended_levels
    Directions for removing stains are in Pool School here: pool-school/metal%20stains
    Post back with any questions and someone will be around to help.
    Welcome to the forum
    You're done SLAMing when:
    ivyleager's Avatar
    Sep 2007
    Raleigh-Durham,NC
    489
    Welcome!
    I had stains when I opened this season too. Pretty frustrating, but pretty easy fix. Agree with Butterfly that your PH and TA need adjusting first, and sooner the better. That can be accomplished with soda ash (read and retread pool school). Don't add any more chlorine, as it needs be close to zero when you do the actual stain treatment. In the meantime, order some ascorbic acid online. By the time it arrives, the chlorine should be low enough to start.
    The link above on metals and stains has step by step instructions. Also, here's my thread on my attempt to remove metals:
    stains-but-how-why-t43678.html
    Good luck!
    CaryB
    36 x 18 IG vinyl, 25K, 1 HP pump, sand filter
    1 skimmer, 2 returns, no main drain
    Old school: PoolSolutions test kit
